Pressure tap for OS91 ducted fan?
Can anyone tell me where or how to pressurize the fuel tank on my jet?It is a OS91 ducted fan with a byron fan and pipe and I would like to put a pressure nipple on the pipe but need to know where.Thanks Bill
IL
Typically, the pressure take off is at the pipes largest diameter. That's where I put it on my setup, and it works as advertised. Back in the day, all the pattern fliers that I knew had the tap there, and it worked for them, so I just copied. Hope this helps.
