RAM ECU
FL
RAM ECU
I am having a problem with a RAM ECU on a 1000. When I hit run to start the startup sequence it starts by activating the gas solenoid like its supposed to. Then before it gets to the next step it gives a NO RX SIGNAL. Now this does not happen everytime. Its more like a 50/50 everytime I hit run on the GSU. I replaced the cable that goes from the ECU to the Throttle channel already. That did not help.
If anyone has had a similar or same problem and knows how to fix? Please send me an email. Thanks.
[email protected]
[email protected]
RE: RAM ECU
actually call Bob Price, he designed it, built them, and repairs them.
[email protected]
512-259-9232
Dawn
[email protected]
512-259-9232
Dawn
FL
RE: RAM ECU
Before starting your engine check for RX voltage. 5.5 or 6.5 on your start box . If there is no voltage connect any servo on the throttle channel and do your range check. It could be your receiver. Or take a magnet pass it around the RPM sensor area.
Hope this help
Hope this help
FL
RE: RAM ECU
Well I spoke with Bob today and the answer to the question/problem was. BAD BATTERY!!
I replaced the battery and everything is working fine now. Thanks for all who helped.
