turbines
FL
turbines
Hi all are there any companies out there that sell turbine kits ? for big planes ?Are there any books out there that tell and show you how to scratch build turbines ?are they relieable ?
Guardian
Guardian
ON, CANADA
Kit/Sctarch built Turbines
Hi Guardian
There are a number of companies that sell kits. We carry two from SimJet. They produce 17 and 23 lbs of thrust respectively.
There are also a number of books and plans available which will give you the plans and instructions to construct your own turbine. Check out the GTBA website for more info on plans and materials.
Please review the AMA requirements for homebuilt engines before proceedin to ensure that the engine you are building will meet their requirements.
If I can help in any way, please let me know.
Ed
Ed
CA
JDE 54
Hi Guardian
If you are interested in a turbine kit engine or assembled tested and ready to go Turbine engine AMA approved and serviced in the US check our web site (JDEnterprise.net)
Dennis Fuente
JD Enterprises
Wren Turbine
Dennis Fuente
JD Enterprises
Wren Turbine
FL
turbines
Check here:
http://www.jdenterprise.net/WEng/WEng.htm
That has prices for different purchase options of the MW54.
Dennis, what options/prices are there on the -44, or when will it be available? Will it be a kit as well?
CA
JDE 54
The price posted on my web site for the engine as it would be supplied from the Wren directly with out the AMA approval and then the JDE 54 with AMA approval.
We will supply the engine in either form so no reason to purchase the engine from the UK and then have to go back to the UK for support JDE will sell and support the engine in the US for the Same price.
I know there is a lot of other manufactures making statements regarding the 44 size turbine but it is not available from any one.
I have the first engine coming, Team Wren UK is using the engine right now in one of the trade shows in Germany and as soon as they return it is to be shipped over to JDE.
There is not many of the engine made at this time there has and will be continued upgrades and changes to the design up and until Mike is happy with the way the engine performs.
The Word from Mike is he has made a change to the Combustion chamber and now feels the engine performing as it should and has started to go into production of the parts for it.
It will be several month's before a production run is made.
If you still have questions i am available to answer them at
650-359-0406
Regards
Dennis
JDE
650-359-0406
Regards
Dennis
JDE
ON, CANADA
SimJet Turbine Kits
Hi John
The SimJet Sonic 7000 and Sonic 8000 kits are fully AMA approved and come complete with ECU, valves and full auto electric start. Nothing else to buy. The Sonic 7000 Kit is $1849 and the Sonic 8000 Kit is $2099. The price also includes final balancing and return shipping.
If you have any questions, please feel free to ask.
Ed
Ed
CA
JDE 54
Hi Jeff
The AMA approved version is the JDE 54 I have the kits and assembled engine's AMA approved along with the free wheeling Turbo Prop and Heli interface.
The kit is completely machined and all the attaching holes are drilled and threads tapped the kit requires balancing there is a manual that outlines this function or you can have the kit balanced electronically here at the factory at time of purchase.
Most of our customers assemble the engine in a weekend; the engine has a trust rating of 12 lbs.
BRG's
Dennis Fuente
JD Enterprises
BRG's
Dennis Fuente
JD Enterprises
