 HELP  NEED STAINLESS PIPE >
Old 10-18-2004 | 01:52 PM
My Feedback: (9)
Default HELP NEED STAINLESS PIPE
I need a Stainless steel pipe for a Rossi 105df FAST!!!!!! can anybody help me with getting one?
Old 10-18-2004 | 02:38 PM
LGM Graphix's Avatar
My Feedback: (22)
Default RE: HELP NEED STAINLESS PIPE
Why do you need a stainless pipe for a ducted fan? you'll have better luck with a glass pipe, both for weight, and for the area ruled ducting. trying to get a nice tight seal in the duct work with a stainless pipe will not be easy, and you won't find an area ruled duct in stainless.
Old 10-18-2004 | 03:29 PM
grbaker's Avatar
My Feedback: (29)
Maybe he's talking about a tuned pipe?
Old 10-18-2004 | 03:34 PM
mr_matt's Avatar
My Feedback: (10)
Rossi 1.05s run hot and generate massive exhaust flow, I have heard of one melting the joints on the (tuned) pipe
Old 10-18-2004 | 04:17 PM
My Feedback: (9)
Yes that is exactly what has happened, it has melted down twice, the airplane that it is in is a government peice (experimental UAV) the ducting of the thrust is completly diffrent than anyone here has been exposed to due to the patients on the design, basicly in generic terms the bypas of the thrust blows through a plenum and vectors through the center wing of the aircraft, it exhaust out the trailing edge of the center wing, the plenum was designed so that the exhaust is not in the airflow exiting the wing, this is due to the fact that I can not have any heated exhaust coming out. (GOVERMENT, does not want any type of heat generated behind the bird due to STEALTH TEC.) anyhow I cant keep this pipe from melting down because it is not in the airflow. does that help any? Thanks Chris
Old 10-18-2004 | 04:42 PM
Hi Chris
This might sound like a dumb question, but if the exhaust can't exit the rear of the aircraft, whre does it go?
I have an idea that might help, but need to know the above answer.
Ed
Old 10-18-2004 | 05:18 PM
jetdriver's Avatar
deleted by jetdriver
Old 10-18-2004 | 05:54 PM
seanreit's Avatar
My Feedback: (60)
You can do a mini radiator with a windshield wiper pump but the pipe will need to be made with a heat exchanger. Find your custom pipe man, and you should be able to get it done from there.
Old 10-18-2004 | 07:23 PM
A few years back Sig sold a pipe just for the Rossi that would take the heat I tried one and it worked. I don't know if they still sell Rossi stuff or not, but you can give then a call.
John
Old 10-18-2004 | 08:26 PM
Countryboy's Avatar
My Feedback: (25)
ORIGINAL: airmcn_3
Chris,
You may want to check with Bruce at http://www.centuryjet.com/ CJM used to carry a large volume pipe specifically for the Rossi 105, but I don't know if they still stock them.
Old 10-19-2004 | 09:26 AM
My Feedback: (9)
Cool Thanks Guys this will help me get in the air. as soon as I do so I will post pics! Until I do the maden flight I cant discuss too much but this thing is cool, you can get an Idea of the Technology through our toy business at www.iwatoyco.com This will give you a good overview of the technology and soon you will get to see the real thing! Thanks for all the help!!!!! Chris Mc Nair
Old 10-19-2004 | 09:44 AM
tomcatman's Avatar
Those gliders are AWESOME!!!! I can't wait to see this project of yours!!!
