Brake lubrication ?
ID
I have a question about what everyone is using to lube the rubber bladders in the brake hubs to keep them from grabbing. I have used vaseline in the past......haven't flown in a couple of years....and was not happy with it. It will cause the bladders to swell over a period of time and cause a lot of drag. Is there something better on the market now? ( BVM wheels and brakes )
ID
HUMMMM,
The key seems to be in using a silicon based product as it doesn,t affect the rubber components the same way petroleum based solutions will, i.e., expand the rubber.......good suggestion....thanks
rcs1313,
I've been using White Lithium Grease for a couple years and it works great. When my brakes start getting a little "grabby", I clean the hubs, bushings, axles and o-ring, then I wipe a thin coat of grease on the o-ring and axle before re-assembly. The product that I have been using is available from Permatex in a 1.5 oz tube (part number WL-9) which should last for many many brake lube jobs. The Dielectric Tune-up Grease is available in a 3 oz. tube (part number 22 058) also from Permatex. Your local auto parts store should have both of these.
Happy New Year!
John
Happy New Year!
John
