 outside diameter of dynamax..? >
Old 12-30-2004 | 12:31 AM
razorice79's Avatar
Default outside diameter of dynamax..?
Stupid question but need to know...[:-] Im just ordered some mylar to attempt to make my first thrust tube.. I need to know if I make the thrust tube diameter for the fan shroud at 5 1/4" or is this the inside diameter of the dynamax? I cant get to my fan unit without tearing out the ducting,etc to get a accurate measurement.. Do I need to make the thrust tube say 5 1/2" inchs to compensate for the plastic shroud material thickness? Basically, I just need to know the measurement of the outside perimeter of the back end of the dynamax fan shroud.... thank you in advice...
I hope someone understands what measurement I want.. its late (cant think)
[sm=stupid.gif][sm=redface.gif][sm=idea.gif]
[RaZoR] out..
Old 12-30-2004 | 12:48 AM
My Feedback: (29)
Default RE: outside diameter of dynamax..?
I just happened to have one on the shelf here...it is 5 1/16" outside diameter of the rear shroud.
Happy New Year,
Rob / pickupsticks
Old 12-30-2004 | 12:55 AM
KFalcon's Avatar
My Feedback: (18)
I measured the DF ducting for a Y/A F-18 twin, The ducting is 5 1/4" at the fan end and tapers to 3 5/8". Yellow ducting is made for the Dynamax fan. Hope this helps.
Old 12-30-2004 | 05:22 PM
razorice79's Avatar
thanks for the info!! I decided to make a new thrust tube from 4"inch exit to 3.75"inch,... if thats not enough static I'll make a second with 3.5"inch.. I guess its time for some Trial And Error...
[RaZoR][sm=lol.gif]
