 Sky Master Hawk Maiden >
Old 03-13-2005 | 05:05 PM
  #76
AirPac Models's Avatar
Default RE: Sky Master Hawk Maiden
Woketman
The fuel capacity in the tanks (2 tanks) total is about 110oz.
Old 03-13-2005 | 06:56 PM
  #77
tp777fo's Avatar
My Feedback: (28)
David G.... how about some pix of your gear door set up.. thanks
Old 03-13-2005 | 07:42 PM
  #78
David Gladwin's Avatar
I haven't yet got the MLG inner doors done, but the other are done. Will that help? The lack of these inner doors may be what gave the model such a delightful sound and with the 160 running at a relatively low rpm it was all VERY quiet.
Regards, David.
Old 03-13-2005 | 08:17 PM
  #79
Charlie H.'s Avatar
My Feedback: (38)
HI David
Congrats on the maiden flight , can't wait to get mine in the air . What did you use for flap settings on take-off and landing and did the nose want to pitch down on you , at full flaps ?
Charlie
Old 03-13-2005 | 10:22 PM
  #80
Absolutely benign handling.
As Ali suggested I used about 15 mm flap for take off, 30mm for landing . It needed 1/8th inch trim, measured at t/e of stab, with flaps at t/o and another 1/8th at full flap. Use that as a starting refernce . I am using flight modes for flap selection and trims are memorised in each flap setting. I will adjust the flaps for progressively more deflection as pitch response with twin servos is not a problem. You'll love it.
BUT if you look at the cutaway in the wing rib to allow the main retract cylinder to fit, too much of it has been cut away, mine broke here curtailing flying. Re-inforce this rib.
Regards,
David.
