 Engine Info Needed For Design Project >
Old 04-30-2005 | 08:49 PM
Default Engine Info Needed For Design Project
I'm an aerospace engineering student, and over the next year I plan to design an r/c plane. The plane only has two purposes; it has to fly very fast and carry a small video downlink. A turbine would not fit into my budget, so I'll probably use a large glow powered ducted fan (at least 12lbs of thrust). I fly r/c's, but I don't have any experience with ducted fans. I would very much appreciate any information on calculations, fan units, motors, manufacturers, etc... Thanks
Old 05-01-2005 | 09:40 AM
My Feedback: (10)
Default RE: Engine Info Needed For Design Project
a byron fan assembly puts out 12 to 14 pounds of thrust pending on the outlet of the thrust tube you can buy them on ebay or here on rc univerise i am all for the byron fan because its a pusher fan so the motor is in front of the fan and does not interfere with the air flow in the thrust tube you being a areospace engineer understand the propertys of air flow and restrictions of air from stationary obstacles interfering in the airstream just my opinion good luck with your project keep us posted on your design of aircraft donniercjet
