 EJF Bob-e-cat >
EJF Bob-e-cat
EJF Bob-e-cat
Old 06-23-2005 | 11:45 AM
CARS II's Avatar
My Feedback: (7)
Default EJF Bob-e-cat
Has any one converted an EJF Bob-e-cat from electric to turbine (MV 44 or simjet 700 ), If so can you give me details like where to reinforce the composite kit and if the wings can be made removable to be able to transport in an airplane as a chek bag.
CARS II
Old 06-23-2005 | 12:03 PM
Bob_B's Avatar
Default RE: EJF Bob-e-cat
This model is just to small to make into a turbine powered version. Mainly as there would be no place to put the fuel tanks or they would be very small and I do mean very small!
Look at the build thread on the ezone and see how tight the batteries fit in.
Bob
Old 06-23-2005 | 12:04 PM
I contemplated this after seeing the success my friend Neil had with his small bobecat on EDF. I decided against it in favour of the Jetco (bobcat lookalike) as the Jetco was designed for small turbine and John Agnew has successfully flown his with mw44. Although with a little work, the Composite bobecat would probably be fine for 44/700
Old 06-23-2005 | 04:06 PM
CARS II's Avatar
My Feedback: (7)
Thank you for the replies guys.
CARS II
Old 06-24-2005 | 06:14 AM
Cars 11
The Bob -E- Cat is too small for a turbine. I had a look at it too and although the turbine might fit it would not carry enough fuel unless you use a plasma bag or similiar ( I think these are banned in the US?) The wing loading would be quite high also. As Dave says the Jetco flies well on the Wren 44 if you like that shape but it won't go in a checked bag
John
Old 06-24-2005 | 08:23 AM
CARS II's Avatar
My Feedback: (7)
I like more info on the Jetco Bobcat and where to get them.
Niceeeeeeeee looking Cat, can you give me more specs on this airplane.
CARS II
Old 06-24-2005 | 08:49 AM
Cars 11
The model in the photo is the Jetco it is a German model produced by Peter Adolphs. If you enter Jetco/Wren 44 in the RCU search box it will lead you to a build thread on the model and all the information you will need is there.
The Jetco kit costs around $400 compared to the Bobcat at $2,000 by the way although you have to do more work on the Jetco.
John
Old 06-24-2005 | 09:12 AM
CARS II's Avatar
My Feedback: (7)
Thank you John.
CARS II
Old 06-24-2005 | 10:41 AM
SJN
http://www.paf-flugmodelle.de/Jetco/jetco.htm
My friend also has one, though powered by a simjet 1200.
One of his best flying planes.
ID:	289192   Click image for larger version
ID:	289193   Click image for larger version
ID:	289194   Click image for larger version
ID:	289195   Click image for larger version
ID:	289196   Click image for larger version
ID:	289197   Click image for larger version
ID:	289198   Click image for larger version
Old 06-24-2005 | 11:13 AM
CARS II's Avatar
My Feedback: (7)
!!Wow!! looks like the simjet 1200 is the perfect size for it, What's the over all weight of the airplane with the Simjet 1200 and How big of a fuel tank can it carry? , How about the retracts?.
I'm got a Simjet 1200 on order to come the next month, so I'm very interested on this kit to have it build as a buck up airplane.
CARS II
Old 06-24-2005 | 11:24 AM
CARS II's Avatar
My Feedback: (7)
Very nice pictures. How can I get one of this kits or how can I order one or should I go over the pound to get one? How big is the shipping box? Haaaaaagggggggg, all this questions.
Thank you
CARS II
Old 06-24-2005 | 12:21 PM
CARS II's Avatar
My Feedback: (7)
Hey John, How come your airplane doesn't have an engine and what did you end up putting in it.
CARS II
Old 06-24-2005 | 02:38 PM
SJN
My friends weigs 7kg dry
It has a 2liter tank in it.
One "con" of the kit is that there no formers included in the kit to fit in the fuselage. There are some drawings so you can cut your own to install retracts.
Old 06-24-2005 | 04:12 PM
CARS II's Avatar
My Feedback: (7)
I have done that before so it shouldn't be a problem, but fun instead.
Thank you.
CARS II
Old 06-24-2005 | 05:12 PM
CARS II's Avatar
My Feedback: (7)
John, I could not find the tread on the Jetco B. cat , can you help me?
Thank you
CARS II
