Reload this Page >
THE RETURN OF THE VIPERJET
Old 08-02-2006, 09:49 AM
  #201
c/f
Default RE: THE RETURN OF THE VIPERJET
Miguel,
I'm sure turbine pushing is not an issue with turbine placement, As you can see here, I cut off the fuse at the gray paint portion of the tail, I also moved the turbine as far forward on rail mounts as possible without altering them as the tanks would not fit by extending rails forward. The pipe exit however is still exiting in original position as I made the new exit former prior to cutting off tail end. I did have to shim turbine mounts to achieve a straight thru centerline. I accomplished this by making a dummy turbine out of PVC pipe with end caps. Using a laser beam in front cap, shooting thru a small hole in rear cap, I then insured the laser spot was centered in rear exit by placing a piece of paper over it with cross hairs in center. My Viper has no additional ballast to achieve center c/g location of OEM......
I do fly kangaroos, bobcats, and Kingcats so I know what pushing is and the Viper Jet MKII has none of that. Go for it.......
Old 08-02-2006, 09:55 AM
  #202
c/f
Kevin,
As for crow, YOU need to go for it, next time your field charging batteries you could do a seperate aileron lead........
My first turbine was a Kangaroo, being anal about weight and c/g positions and methods of measuring I not once kangarood it and its still in new condition, HOWEVER I've KANGAROoo'ed the Kingcat half a dozen times until I went to crow mix for landing.
Old 08-02-2006, 12:02 PM
  #203
amjflyer
I dont use crow on the KC unless is very windy, full flap only is fine they are like barn doors. Its the only jet ive ever flown that will land at 20mph, unbelievable. Having said that for aerobatics and looks in the air the viper beats it and at about 1/5 of the price.
Old 08-02-2006, 06:05 PM
  #204
c/f
Is 20MPH a guess for KC landings???
I can only get to 32MPH at full 3 point stall according to the onboard Eagle Tree
Old 08-03-2006, 04:26 AM
  #205
amjflyer
20mph with an average 10mph headwind, so your onboard telemetry is spot on. But in tests i did it definitely landed slower with full flap and no crow (so i have it switched seperately) than with flap and crow. The roll out on grass is well under 100ft, no brakes.
Old 08-18-2006, 09:01 AM
  #206
mu2driver
My Feedback: (15)
mu2driver's Avatar
Hey guys looks like I joined the V.I.P. club with my new Super-ViperJet...
I just started it yesterday with my P-120 Kero..what a sweet running turbine, first try just ran like it should...
Well I just wanted to share with you the latest addition to my growing fleet...
Yes its in my room, I live where its Hot as Hell, so untill I spring for an A/C I just build em in my kitchen
Old 08-18-2006, 03:48 PM
  #207
amjflyer
Well you wont regret that move mu2driver! The Viper is the first scale jet ive flown that needs very little mixing for full aerobatics without correction.
Old 08-18-2006, 03:54 PM
  #208
mu2driver
My Feedback: (15)
mu2driver's Avatar
Well Im impressed already with it! Looks like a well built airframe, the wings are heavy but very strong!
I have it almost ready to fly, just waiting for Robart to get my gear and im set...
I just looked and my name is finaly on the Waiver list...
All in all not a bad buy for 800 bux...
Old 08-18-2006, 04:02 PM
  #209
amjflyer
err yeh, comapred to the giant scale aeros these jet airframes are a bit on the heavy side, esp. the Viper. But at 100mph theres no lack of lift, just dont try Walls...
[8D]
Old 08-18-2006, 04:16 PM
  #210
mu2driver
My Feedback: (15)
mu2driver's Avatar
Yeah im hoping for 200, from everyone I have talked to they all say its a real good flyer, just a pain to put together at the field..
This one is setup with 8411's on Flaps, 9411's on Elev. and Aileron, 8611A on Rudder
From Tam I got the Wing Light kit, Smoke pump, Fod Screen with festo fittings, Smooth stop, ext....
Now I will call him and get some more stuff...
Old 08-19-2006, 10:44 PM
  #211
mu2driver
My Feedback: (15)
mu2driver's Avatar
Hey just a quick question for you guys in the know...
How far does the P-120 need to be from the begining of the tail pipe?
Also does it need to be dead center? and how are you guys getting it dead center? Laser?
Thanks a million!
Old 08-20-2006, 02:51 AM
  #212
amjflyer
Mine isnt dead centre its a little high on alignment with the pipe, but is about 1in. away from the end of the pipe (ie 1in. gap between the end of the p120 tail cone and the beginning of the stainless pipe). I couldnt find an elegant way for the bypass to fit correctly around the turbine and get the tail cone dead centre. Although this seems to work fine and temperature inside the rear is barely above ambient for the duration of a flight.
Old 08-20-2006, 04:40 AM
  #213
mu2driver
My Feedback: (15)
mu2driver's Avatar
Ok thanks, mine is also a bit high I thought, but I guess this is ok for now...
Oh yeah this kero start is bad ass...
Old 08-20-2006, 05:26 PM
  #214
CARS II
My Feedback: (7)
CARS II's Avatar
Are you getting close to the maiden flight?
ID:	510297   Click image for larger version
ID:	510298   Click image for larger version
Old 08-20-2006, 07:12 PM
  #215
mu2driver
My Feedback: (15)
mu2driver's Avatar
Yeah Carlos, im just waiting for my parts from Robart, then I need to rebuild the gear and make sure all controls are setup...
Its getting close...
Old 08-20-2006, 11:24 PM
  #216
CARS II
My Feedback: (7)
CARS II's Avatar
Darcy
I have been flying my Roo for the past two months, my friend is taking over the Roo with his engine and I'm back flying the Viperjet after next week, should be fun. [8D]
Are you coming to Fresno with it?
Old 08-21-2006, 04:24 AM
  #217
amjflyer
Darcy
What made you choose the Robart gear over TAM ?
Old 08-21-2006, 08:26 AM
  #218
mu2driver
My Feedback: (15)
mu2driver's Avatar
Carlos Yes I sure am, I will leave early Friday and grab a Hotel, should be a blast man! ViperJet Formation?
Alan, I bought this thing used and it had the Robarts, I called Tam and he did have any available gear he wanted to sell...I just want something reliable and if these Robarts are not I will try Behotec next...
Old 08-21-2006, 09:11 AM
  #219
amjflyer
Darcy, Robarts are no problem someone else i know is using them i just wondered why you made the choice (i think the TAM ones look a bit nicer thats all) [8D]
Old 08-21-2006, 09:19 AM
  #220
mu2driver
My Feedback: (15)
mu2driver's Avatar
I wish I could get the Tam gear but I cannot, unless someone knows the source? Cermark?
Old 08-21-2006, 06:20 PM
  #221
CARS II
My Feedback: (7)
CARS II's Avatar
Call Tod at Dreamworks, I think I saw them there too.
Old 08-21-2006, 06:47 PM
  #222
mu2driver
My Feedback: (15)
mu2driver's Avatar
I did talk to him, he didnt have anything...
Old 08-21-2006, 09:53 PM
  #223
CARS II
My Feedback: (7)
CARS II's Avatar
I guest you are using Robart, noting wrong with them I think.
Old 08-21-2006, 10:08 PM
  #224
mu2driver
My Feedback: (15)
mu2driver's Avatar
Other than there slooooowww service....
I could call Cermark and get the latest gear there selling in the New kits but for now I will try what I got...
Old 08-21-2006, 10:28 PM
  #225
CARS II
My Feedback: (7)
CARS II's Avatar
Yeap, recycle your stuff, no point on buying more stuff when you have it already.
