AMT Concorde? >
AMT Concorde?
AMT Concorde?
Old 01-10-2002 | 01:58 PM
ckoerner's Avatar
Default AMT Concorde?
What ever happened to it? I heard they where going to build a smaller one first to find the correct CG or something. Do they plan on flying it? Just curious. That's all.
Craig
Old 01-10-2002 | 02:11 PM
My Feedback: (10)
Last I heard they were working on thrust reversers.
Old 01-10-2002 | 03:23 PM
Default Concord
I attended the mid-america fly in last fall and saw the smaller one fly. it flew very well i might add.
Old 01-11-2002 | 03:59 AM
Default the 'small' one
How 'small' is the smaller one?
Old 01-11-2002 | 05:14 AM
Default concord
hard to tell. i know it was powered with a turbine. looked to be about 15 to 20 lbs, 6/7 ft long???? wings pink foam not covered.
Old 02-20-2004 | 12:43 PM
Rex's Avatar
Rex
My Feedback: (18)
Default RE: concord
Has anyone heard the status of the big AMT Concorde lately? It came up during a discussion among modelers the other night. A search yielded this thread, but I notice it is old!
Old 02-21-2004 | 03:59 PM
David Gladwin's Avatar
Default RE: AMT Concorde?
If AMT need the correct C of G I can fix that !
At low speeds the Cof G needs to be at 54 % of the root chord. However, once supersonic they will need to move it aft to 58% at Mach 2 and then return it progressively to 54 % during the decell.
BAC and Aerospatiale found a trim tank in the tailcone the best answer, worked perfectly , and eliminated trim drag considerably improving cruise fuel burn.
However, this will only work if the AMT Concorde wing is exactly the same shape as the original Concorde and that shape is VERY complex with twist, camber and droop , particularly the outer panels.
David Gladwin
Old 02-24-2004 | 04:21 AM
Correction, the forward point of the C of g should read 53% of root chord. DG.
