 Augmented thrust tube >
Old 11-08-2005 | 07:19 PM
Terry Holston's Avatar
Default Augmented thrust tube
I have been trying to find the drawings for the augmented thrust tube that Wren developed for their MW54.
The one that is supposed to add thrust. I want to make one for my Ziroli Panther. (Need all the thrust out of my 'ol 500 I can get..........
I tried Wren's web site and could not find it.............
Couldn't find it on the GTBA site either................
Anyone??????????????
Old 11-08-2005 | 07:23 PM
Thud_Driver's Avatar
Default RE: Augmented thrust tube
April/May 2003 and February/March 2004 issues of RCJI.
Old 11-08-2005 | 07:34 PM
grbaker's Avatar
My Feedback: (29)
I got some specs from Gudmund Malones (that he got from John Wright @ Wren) so I could build one for my Eurosport / Titan. If Gudmund doesn't chime in by the time I get off work, I'll try to find it and send it to you.
My Titan gained about 3 pounds of thrust on my test stand using the pipe I built.
Old 11-08-2005 | 07:40 PM
Terry
Send Wrens an E-mail. Nowadays they make a series of standard thrust augmenters designed for different engine sizes and jet exhaust speeds, which you you can down to the length of your model. They are not very good about advertising their wares as they have quite a range. Each tube comes with its installation diagram. Very high speed/supersonic exhausts (such as the SuperSport) can genereate buffeting inside the tube and they have developed a slightly different and stronger design to cope with it.
If you send them the details of your model's requirement and the engine you plan to use - they are always very helpful.
Old 11-08-2005 | 07:58 PM
ORIGINAL: Thud_Driver
Just wentthru all the back issues I could locate and those issues are not in my collection.......
Can some one post the schematics od pictures?
Old 11-08-2005 | 08:05 PM
DCM's Avatar
DCM
My Feedback: (15)
ORIGINAL: Terry Holston
Click on this http://www.wren-turbines.com/news%20archive%202003.htm at the bottom of the page click on "new design"
David Hudson
Old 11-08-2005 | 08:18 PM
I have scans of the four pages at about 2,000kb each. Is it ok by RCU to post scanned magazine pages - copyrighted material??
I think the link Dave posted answers the question or maybe I can e-mail the scans directly.
Old 11-08-2005 | 08:26 PM
Kevin Greene's Avatar
My Feedback: (85)
Makes perfect sense to me....Exhaust gasses expand when heated and the shape of the pipe aids in exhaust scavenging. The part of a tuned pipe where the pipe gets goes from a small diameter to a larger in diameter works the same way---Exhaust gasses are accelerated as the pipe gets larger. Brilliant!!!
What do you all think??? Is my conclusion all washed up???
Kevin
Old 11-08-2005 | 08:37 PM
Thanks Dave,[8D] that's the one I was looking for, Just didn't dig deep enough I guess. LOL
Old 11-09-2005 | 01:38 AM
Robrow's Avatar
ORIGINAL: grbaker
Hi Gary, can you post dimensions/pics of your Titan pipe ?
Thanks, Rob.
Old 11-09-2005 | 11:15 AM
grbaker's Avatar
My Feedback: (29)
86mm for the inlet and 95.5mm for the outlet with the taper section at 180mm long. These are the specs I got from Gudmund.
I don't think I took any pics of the pipe, but I'll check when I get home.
I would like to try out Mr Wright's design on a bifurcated pipe. It might be possible to build a bi-pipe with no thrust losses.
