BVM Aggressor II
My Feedback: (85)
BVM Aggressor II
I've never seen one converted. Having owned a couple of 'em I can tell you space will be at a premium! You will have to convert the saddle tanks to be able to withstand kero (no big deal) but the problem is that they only hold nine ounces each. Special tanks to convert a Maverick won't work because the Mav fuselage is based on the newer and larger Aggressor III/Ultra Viper format. Another tank could be mounted between the inlets but I still don't think that you will have enough fuel without going to an external belly tank. The largest turbine that would work would be a MW 54 design. (Ram 500/PST 600) Personally, I really don't think it would be worth the effort with the fuel capacity problem and all of the necessary structural mods needed to make the model safe.
Kevin
Kevin
FL
Don't Bother!
Don't bother! There is hardly enough room for fuel for a 5 minute ducted fan flight. I beleive mine has 18 ounces. The plane is already fast enough. The wing loading is high when compared to average jets, so it would be worse when turbineized. The wing may not be strong enough for the loading it could be put through.
The aggressor 2 is a great flying plane, with out a doubt, but a turbine would not make it better.
Just my opinion!
On the other hand, a mav pro could be a great turbine plane. If you want to convert something.
Dustin
Just my opinion!
Dustin
