Futaba 9z question & ROO throws >
Old 11-26-2002 | 03:55 AM
jetspud's Avatar
Default Futaba 9z question & ROO throws
Ok I am trying to get my hanger queen Roo to finally fly I was wondering if there is any way to program the servos in the wing individually with the Futaba 9z. My two servos are Y'ed together in separate channels. I have the hitec digitals would it be easer to just buy the hitec survo programmer?? The problem is when the split elevon, on each wing, goes up or down one goes higher than the other one..
Also can someone give me the throws and exponential they are using for there ROO's........
One of these days it will fly....
I know, Scott it still has not flown... I need to come down there so you can get it going.
Thanks for the info,
David Elizondo
[email protected]
Old 11-26-2002 | 11:56 AM
-JC-'s Avatar
My Feedback: (26)
Default Futaba programming
Hi David,
In the subject line you write 9cap and in the text you write 9Z. Let me know which model it is you have and I should be able to help you with the programming.
Is there any chance you have ATV dialed into the AIL channel?
