I have an odd question ? >
Old 01-26-2002 | 12:34 AM
Default I have an odd question ?
what material is used for turbine exhaust ducts ? the reason i ask is that i wanted to build a sort-of-VTOL aircraft, it would be huge, and i wanted a pair of turbines for lift and a pair for foward flight. It is my own design and I have the duct work figured out , I just wanted to know what material i should use for the exhaust ducting and exit shroud
Old 01-26-2002 | 12:36 AM
Laura H's Avatar
most common is Stainless Steel. But you can get Titanium.
Old 01-26-2002 | 02:03 AM
Guest
My Feedback: (73)
man, thats a small fortune you are talking about ) there !
Old 01-26-2002 | 04:48 PM
Default Yep !
I want to see if i can get a couple of sponsors ( like BVM )here in good 'ol Florida.
Old 01-26-2002 | 05:03 PM
My Feedback: (9)
Default ECU UNIT
Thinking this would have to be a custom programed to control and monitor 4 turbines at once. Reliability might be an issue here.
ECU would have to be very sensitive to monitor thrust output/rpm to make sure at least the vertical turbines were producing identical thrust.
Sounds nice...any pics of your plan.
Old 01-26-2002 | 05:21 PM
Guest
My Feedback: (73)
vario makes a special gyro for 4 pont ccpm swashplates. basically the gyro controlls 4 servos to move the swashplate up and down and cyclic controll .... i can see one of these being used to connect to the ECUs, (all 4, just like servos for the swashplate controll)
the cyclic gyro would then controll the 2 axis in the hovering plane. the gyro would add/reduce thrust as necessary to keep the craft at a stable hover .... put another 2 HH gyros between the cyclic and the receiver , and you have a rock solid hold on the hover. ....
give me the $$$ and ill show you how it can work
Wojtek
Old 01-26-2002 | 10:29 PM
This is what my plane evolved from, needed to be better !
Old 01-27-2002 | 03:06 AM
Default starship troopers transport jump jet?
thats my best guess. either that or off some game
Old 01-27-2002 | 06:18 AM
[QUOTE]Originally posted by wiwanczyk
[B]vario makes a special gyro for 4 pont ccpm swashplates. basically the gyro controlls 4 servos to move the swashplate up and down and cyclic controll .... i can see one of these being used to connect to the ECUs, (all 4, just like servos for the swashplate controll)
Well, the gyro is a good idea to start with. But the biggest problem is throttle lagging. All the helicopter use high speed servos to work with gyro. If the turbine throttle can respond in a split of the second. Maybe it might work.
Someday we get there. Just keep on imagine.
Brg,
Tam
Old 01-28-2002 | 08:52 PM
Default ram 1000's , or AMT 1500's ?
which would give better verticale lift for a plane that is 134 "long, and 33"tall and 40"wide ( almost half the length is tail) RAM 1000's, or AMT 1500's ,which is better in the long run, oh ,and the plane is going to weigh 35-40lbs .
