Rossi 90 Help
I have recently purchased a Rossi 90 from a friend. This Rossi came with a Heat sink head on it. My problem is that this head is too large to fit into my Phantom. Does any have a standard Rossi 90 Head with the button and screws that are willing to either Sell or trade for the Heat sink head that I have?
My Feedback: (45)
If you don't need the head in the future, and don't mind carving it up a bit, just trim it down to the size that you need using a hack-saw. Then clean up the rough edges with some sandpaper or a bench-top belt sander. This is what i did on one of my rossi's. The best is to find a small head, but if you can't, this should get you going. Hope this helps
John
John
I found a hobby shop that deals with Rossi Engines and parts. They had a standard Rossi 90 head in stork. The name of the hobby shop is called Morris Hobbies 800-599-6887 is anyone else needs Rossi Engines or prats.
