 Jetlegend T-45 Hawk >
Jetlegend T-45 Hawk
Jetlegend T-45 Hawk
Old 01-20-2009, 11:40 PM
  #751
My Feedback: (52)
Default RE: Jetlegend T-45 Hawk
Thanks Rich.
Paul
Old 01-24-2009, 11:03 AM
  #752
i´m work in my t-45.
My elev. system is the original ( ready for one servo 24 kg only )
is this configuration good for my t-45 / p-60 ????
why some people change some pieces ?????
Old 01-24-2009, 11:28 AM
  #753
My Feedback: (44)
RCISFUN's Avatar
Because of the slop that will grow worse with use in the factory elevator assembly, you need to go back through the thread to get the details
Old 01-24-2009, 12:06 PM
  #754
FILE IFR 's Avatar
ORIGINAL: guilifog
That will be fine with a P-60
Old 01-25-2009, 04:02 PM
  #755
file ifr , fly you whit p-60 ?
if i don´t change nothing of my elevator ????
thanks for the info!!!
Old 01-25-2009, 04:34 PM
  #756
My Feedback: (44)
RCISFUN's Avatar
The size of the turbine has nothing to do with the slop that will eventually develop.
If you don't have any slop now just fly it
When slop develops you can make the modification.
Old 01-28-2009, 12:54 PM
  #757
hello everybody
my name is jean-pierre I live in France and I just recieved my t45!
Do you have balanced elevator? my elevator servo is a hitech 7955TG so I think that it's not necessary but in your opinion what may I do?
thanks
JP
Old 01-29-2009, 05:34 AM
  #758
Hi Jean-Pierre,
I installed also a Hitec 7955 for elevator, it's pretty too much, but will be ok.
My factory elevator mechanism is tight. I will not change it for the moment.
Carlos
Old 01-29-2009, 06:50 AM
  #759
FILE IFR 's Avatar
ORIGINAL: guilifog
Will you fly off of grass or pavement?
Short cut grass and a P-60 is ok.
Old 02-18-2009, 05:41 PM
  #760
i will fly on pavement.
some people says that this powerplant are little for this plane.
somewhere fly the t-45 whit the p-60?????
Old 02-19-2009, 06:58 AM
  #761
My Feedback: (44)
RCISFUN's Avatar
My buddy flew this model with a Wren 54 MkIII; it flew it very scale like.... it certainly wasn't overpowered
Then he put a P70 in it....it was night and day difference.
Mine had a Jet Central Falcon, it was a rocket ship in verticals, the overall horizontal speed wasn't much different than the P-70 powered model.
Old 02-19-2009, 07:45 AM
  #762
snir2001's Avatar
You can see mine with P-80, it's flying great.
This flight the camera man was somewhat drunk... and the front gear didn't lock up, but anyway, you can get the speed feeling.
The verticals with the P-80 are more than enough.
http://www.youtube.com/watch?v=8w-Jk...eature=channel
Old 02-19-2009, 07:55 AM
  #763
Xairflyer's Avatar
I always thought a P80 would be perfect for this plane, why do they say in the instructions not to use one
Old 02-19-2009, 07:57 AM
  #764
My Feedback: (44)
RCISFUN's Avatar
BTW, the Jet Central Falcon is smaller in Diameter and produces more thrust than the Jet Cat P-80
Old 02-20-2009, 06:33 PM
  #765
ok, all that are very well,but....
CAN THIS PLANE FLY WHIT MY P-60 AND PAVIMENT ????????
Old 02-20-2009, 07:03 PM
  #766
My Feedback: (67)
Keep it light and it will fly with a P60 from a paved runway.
Check out my landing gear doors modification. I will try with longer reach air cylinders so they will look more scale.
With these boosters, it only takes 40 - 60 psi to retract the gear.
Mike
Global Jet Club
ID:	1140675   Click image for larger version
ID:	1140676   Click image for larger version
Old 02-20-2009, 07:36 PM
  #767
My Feedback: (44)
RCISFUN's Avatar
Mike that looks great, are you bringing the T-45 to FL Jets?
Old 02-20-2009, 08:48 PM
  #768
My Feedback: (67)
Hi Rich,
No, I left it in Asia, because it's a good beach goer, so I did not bring it back this time. Will bring F16 Ace and F18 Chippy Ho to Florida Jet.
Mike
Old 02-21-2009, 01:34 PM
  #769
snir2001's Avatar
Hi Guilifog,
I did a test flight with my P-80 turbine limited to 114000 RPM, that give me a 13 Lbs of thrust, the same like your p-60.
Well, it's flying, and very well I have to say.
After flying with P-80 I do feel like under power, but the hawk flying good enough.
I think that your hawk will fly better due to a smaller amd more light turbine.
Old 02-22-2009, 06:03 PM
  #770
thanks to the friend from israel for your test.
i hope that my t-45 can be fly whit the p-60.
i don´t would to find a high speed fly, only a
scale jet plane.
thanks.
Old 03-15-2009, 10:58 AM
  #771
My Feedback: (51)
Guys,
Has anyone managed to get the gear doors to run well ? if so, pics and info would be great.
Also, any mods required on this airframe ? im htinking about one for my AMT 180SP (20lbs).
Old 03-15-2009, 08:27 PM
  #772
My Feedback: (44)
RCISFUN's Avatar
If you order from Mike D at Global Jet club you will receive the elevator mods with the kit.
Old 03-16-2009, 02:17 AM
  #773
snir2001's Avatar
Hi Lior,
The problem with the gear doors is the size of the gear cylinder.
It's just too small, and will not retract the gear with the door attached to it with normal pressure (100 ~ 110 Psi) during flight.
I'm starting to work on mine and I think to install a booster like mikedenilin.
Any way, I think that the most important thing is the elevator mod. I used RCISFUN (Many Thanks !!!) plans and it eliminate the huge slop in the elevator.
Now I'm flying the model almost every weekend and having a great fun…
Call me if you need more info.
Snir
Old 03-16-2009, 05:48 AM
  #774
My Feedback: (51)
Snir,
Send me your #. would love to meet up with you and see it fly, possibly even take her for a spin ?
Old 03-16-2009, 05:57 AM
  #775
snir2001's Avatar
Lior,
054-6447007
Snir
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
