FUTURE ON CANOPY'S---Wow
My Feedback: (84)
IA
I wiped it on as stated earlier and it dried to a streaked finish. So what do I do now and what do I do different in the future (no pun intended) to prevent this? thanks
My Feedback: (164)
CA
Hi Eagle:
If you keep wiping till it dry's then you will get the streak. You must apply very wet. Two swipes each side. To remove follow the instructions on the back. But before you do, try another coat and see if it will remove the streaking
Dave R
Dave R
AZ
I tried this on my canopy as well. While I applied it wet, it dried with several areas sagging, not to cool. I dipped the canopy in a solution of 1 cup ammpnia to 2 gallons water and removed the Future. Then I tried airbushing the Future on. Got a few runs, did the ammonia trick and decided to leave this idea for another time and place.
