 Servo information. >
Servo information.
Servo information.
Old 01-03-2007 | 02:32 PM
Default Servo information.
On my new model, I will need to run a pair of servos in the rudders and rather than using a 'Y' lead, I was thinking of using Hitec digital servos, with one reversed. I also need to do this on the elevators - I have read that JR Matchboxes are not recommended on flight surfaces such as ailerons and elevators?
What's the preferred method of servo installation - digital reversed or Matchbox?
duthie.
Old 01-03-2007 | 02:37 PM
ravill's Avatar
Default RE: Servo information.
I reverse. Once I trust hitecs again, I'll use them reversed as well.
For now, I'm using reversed JR's.
Raf
Old 01-03-2007 | 03:09 PM
schroedm's Avatar
There are a LOT of guys running matchboxes on primary control surfaces in the giant scale 3D world with no problems where the loads/surface size/deflection are all extreme. I would take that comment about them with a pinch of salt.
Old 01-03-2007 | 03:10 PM
Airforce7's Avatar
My Feedback: (31)
I use two JR matchboxes on my flight surfaces. One for Ailerons and the other for elevator/brakes/canard/thrust vectoring. 128 flights, no problems. Both connected directly to the receiver, no additional batteries to the matchboxes.
ID:	589826   Click image for larger version
Old 01-03-2007 | 04:36 PM
Guest
My Feedback: (73)
I would just get 2 good Hitec servos .. the 5945 servos are great if you want to run a Y-Cable ..... if you have a power box of some sort, or are using separate leads from the RX, i would recomend the 5955 servos .... I chose to go with Hitecs on my JMP Firebird... after doing much research, I believe these to be some of the best servos out there ... no slop, programability, and better reliability than other popular brands ..
Voy
Old 01-03-2007 | 05:26 PM
I'm also a big fan of the 5945MG, although its recely been replaced by the 5985. I have a few of them, but no idea if they work as reliably as the 5945.
Kelly
Old 01-03-2007 | 07:35 PM
ravill's Avatar
If Voy is using 5955's in his jets then so should we. I'm not being sarcastic. I also agree that my 5955's are my favorite servo. I feel very bad that I have relagated all of mine, to steering. [&o]
Voy, I'll PM you.
Raf
Old 01-04-2007 | 01:52 AM
CARS II's Avatar
My Feedback: (7)
I'm running Hitecs on my Viperjet Ailerons and Flaps, steering, awesome deal with the Hitecs been strong, reversable, no slop. On the 9c, If you are running out of channels use Hitecs on the Flaps reprogram the travel and speed and use your nineth channel for Flaps.
