JETJOE Semi-auto Start ECU vs Auto Start ECU
What is the difference in the semi auto start ECU and auto start ECU for the JeoJoe turbines? What is the difference in starting procedure, starting support equipment, and items included with the semi and full auto start packages?
Rob
Rob
RE: JETJOE Semi-auto Start ECU vs Auto Start ECU
The main difference is in full auto its exactly that move throttle trim up and to wide open and back to idle the ecu takes over and engine starts all by its self. In semi auto start you control the gas, glow plug and starter to spin up engine to idle speed after that its the same. Semi auto also saves approx 12 ounces of wieght. Support equipment required is the same only thing extra for semi auto is a wand starter or some other method to spin up turbine to idle speed.
