 Weatronics Receivers >
Old 07-19-2007 | 07:58 AM
Default Weatronics Receivers
Has anyone been having glitches and with weatronics receivers
Old 07-19-2007 | 09:13 AM
My Feedback: (21)
Default RE: Weatronics Receivers
I have been flying two turbine powered jets with Weatronics and found them to be rock solid...no glitches or lock outs.
Richard
Old 07-19-2007 | 02:54 PM
Same here but three!
Old 07-19-2007 | 03:13 PM
I Have over 100 flights on 4 different jets with them, no problems.
Russ
Old 07-20-2007 | 02:08 AM
36 Mhz in australia,
no problems at all. rock solid
Old 07-20-2007 | 03:10 AM
Hi
I have been using weatronics D/R in my jets, however with the advent of the new JR 12 channel 2.4 MHz I am wondering where to go?.
Do I go to 2.4 MhZ and use a PowerBox 40/24 Champion - Li-Po Version or similar or do I stay 35 MHz and use weatronics D/R?
has any one done the comparisons with features and costs?
Kind regards
Derek
Old 07-20-2007 | 07:13 AM
Why mess with success? Only advantage I see is that another transmitter can't interfere with you. 2.4 has its own problems.
Old 07-20-2007 | 10:25 AM
ORIGINAL: stoni1
Hi
Kind regards
Derek
I'm also wondering the same thing?, I tend to stick with the old and trued hardware but not sure on this one.
G.
Old 09-19-2007 | 11:06 AM
felker14's Avatar
My Feedback: (50)
Has anyone used Weatronics in PPM mode with a jet?
Old 09-19-2007 | 12:31 PM
rhklenke's Avatar
My Feedback: (24)
ORIGINAL: felker14
No, but why would you want to do that?
Bob
Old 09-19-2007 | 02:30 PM
If you had a tx that doesn't transmit in pcm mode?
Old 09-19-2007 | 02:50 PM
Banned
My Feedback: (67)
ORIGINAL: rhklenke
ORIGINAL: felker14
Bob
What's wrong with PPM mode?
Old 09-19-2007 | 03:00 PM
Mike Pascoe's Avatar
My Feedback: (13)
MANY flights rock solid on a Airworld 1/5 L-39! Mike
Old 09-19-2007 | 03:13 PM
felker14's Avatar
My Feedback: (50)
Bob
with Futaba 12z PCM1024 = 10 channels with PPM it = 12 channels. I'm have a unit that I'm using in PCM mode. I was just wondering if any body used it in PPM mode could be handy having 2 more channels down the road.
Mike
good to hear you using it in PPM mode. I take you haven't had any problems. Did you set Failsafe up on RX?
Old 09-19-2007 | 03:31 PM
Banned
My Feedback: (67)
I too use PPM24 mode with my Graupner 12 CH RX's with no issues ( knock on wood )..
If I was to make a switch would definitely be to Weatronics.
Old 09-19-2007 | 03:44 PM
DelGatoGrande's Avatar
My Feedback: (23)
Weatronics run on one battery?and when necesery swich to secont?or not?
maybe compination is the best!
powerbox to power Weatronics[8D]lol
Old 09-19-2007 | 03:47 PM
The support is one of the best things, along with the weatronics equipment. Gerhard linked to my computer from his and then to my airplane, he downloaded all the new data, then check all the servos and sync. all the gear doors. The man went above and beyond to help before, during and after the first flight on my plane. The weatronics worked perfect, all i will fly in my Jets from now on.
Randy
Old 09-19-2007 | 04:55 PM
My Feedback: (15)
I got better range on one of my jets which I installed the Weatronic unit. Can't wait for them to come out with the 2.4 system.
Old 09-19-2007 | 05:18 PM
felker14's Avatar
My Feedback: (50)
It does run on Bat 1. Bat 2 is a reserve pack. I think that is why they suggest using LiPo packs because they can handle the amps.
Old 09-20-2007 | 04:34 AM
SpiderJets's Avatar
deleted post
Old 09-25-2007 | 10:55 PM
My Feedback: (29)
wow. look at the price of weatronics now starting at $300 [link]http://rcint.com/electronics_page.htm[/link]
