Thrust angle on a Hotspot
My Feedback: (85)
I would not change the thrust of the engine. Is the airplane sitting level on the ground or slightly nose up? My guess would be that your plane is either sitting level or you have a C/G problem. Slightly nose up will shorten your take off roll. Don't raise it too much. On landing the plane could become airborne again or start to bounce if raised too much. Also, your C/G could be too far forward. There is a lot of latitude when playing with the C/G. Wilcox's suggested C/G is very far forward. I don't have my HotSpot any more...Perhaps those of you that still have your planes could chime in concerning the C/G.
Kevin
Kevin
my c.g. is were wilcox says it should be
with the U.A.T. FULL... my hot spot weighs 20# with a ram 750+ and takes
a couple of hundred ft to get of grass...
rick
rick
My Feedback: (85)
Rick,
I, too, had mine where Wilcox suggests the C/G should be and mine flew fine. I was told by Jason Somes that this location was pretty conservative as he moved his back pretty far. I did have to lengthen the strut some to get mine to rotate better---But, I did have 3 liters of fuel on board!!!
Kevin
Kevin
IN
I have the CG where it said, fuel tank empty. It flew very smooth and rolls were axiel.
I can try a more rearward CG when it warms up here, I don't fly under 50 degrees anymore.
