AVT
Old 11-01-2007 | 09:20 PM
Default AVT
I am setting up my ECU on my Ram 750P and it says to adjust the ATV is required to get the lights to stop flashing.
What is this and how is it adjusted? The manual says nothing.
Old 11-01-2007 | 09:22 PM
Ruizmilton's Avatar
My Feedback: (29)
Default RE: AVT
Which Model do you have? Airstart or autostart?
Old 11-01-2007 | 09:24 PM
Default RE: AVT
Air
Old 11-01-2007 | 09:36 PM
Ruizmilton's Avatar
My Feedback: (29)
Default RE: AVT
PM me your e-mail address, I'll send you the manual for an airstart ECU....
Old 11-01-2007 | 09:48 PM
Default RE: AVT
Just replied in your other thread also but just remembered..... check the servo reverse switch on the throttle channel. If you can't get the LED to stop flashing with any stick / throw adjustment try reversing the switch. The ECU looks for a certain pulse width at full rthrottle vs. low throttle. You'll need to power the ECU down & start over after you do this.
Bob
