Reload this Page >
Skymaster F14 Tomcat
Old 10-11-2014, 03:30 PM
  #1176
FenderBean
FenderBean's Avatar
Originally Posted by DrScoles
Sure like the price on those savox servos. Hung up on sbus though, and if I use the robbe 2018, it's still $40 a pop for the node.
Yelp I have that same problem.
Old 10-22-2014, 03:52 PM
  #1177
Caspa1
Can you confirm all Skymaster F14s should have the new aluminium wing actuators? Is Skymaster still supporting sending the old plastic casing ones back for upgrade?
Old 10-22-2014, 05:05 PM
  #1178
muzzgail
muzzgail's Avatar
I contacted SM about this and they replied with the following words and a photo.
Hi Murray
This update is optional.Anton says it is not must to update.Please check attached photos.As long as you do as per photo,it will be safe and not need to update.
Best regards
John
Skymaster/X-Treme/Skyemaster
Old 10-22-2014, 05:54 PM
  #1179
FenderBean
FenderBean's Avatar
the website says updated which should be for new kits and people who send them back to be swapped. They updated them for a reason, I thought they were replacing them not charging extra.
Old 10-22-2014, 11:27 PM
  #1180
Caspa1
These actuators are confusing. Skymaster has upgraded them for a reason. Anton had said they would replace/upgrade ALL actuators with aluminium casing ones. Alex had some feedback on the end of the actuator. Can anyone else shed some light if they have the updated ones? For something so important on this particular jet maybe Skymaster just wouldn't take any risks and just upgrade everything to be safe.
Old 10-23-2014, 06:59 AM
  #1181
FenderBean
FenderBean's Avatar
getting information to a from these guys is tough, they are having to repaint my f-14 because they cant understand things. Me and my go to guy are beating our heads on the table, both cases it was just s simple color change that has turned into mass confusion. I know that English iis not their native language and it takes time but they should not paint until they are 100% sure. Repainting is adding weight to my jet
Old 10-23-2014, 08:42 AM
  #1182
DrScoles
My Feedback: (18)
DrScoles's Avatar
I was told that Its $250 to upgrade, but they need the old ones back, so you have to ship to Likai. My problem is, the plane is boxed up in storage, no way I'm going to the storage unit, taking it home, unboxing, then reboxing just to get them out. I emailed back asking if I could just buy whole new units. Or, I will do the swap when I finally get to building the kit. These look like firgelli actuators, but they don't have any on their website with metal housings like this.
Old 10-23-2014, 01:19 PM
  #1183
Alex48
Alex48's Avatar
I think the metal casings are made by Skymaster and they are just taking them apart, the did upgrade an internal plastic part to metal. I'm surprised they made this change and are now charging people for it. It appears that i had assumed wrongly that this was free
Old 10-23-2014, 04:30 PM
  #1184
FenderBean
FenderBean's Avatar
Hmm not sure what to think about it all. If there wasn't a problem with the original then why the need for an upgrade? 250 dollars is way to much anyway, they are using firgelli actuators and charging insane prices. Firgelli charges 80.00 dollars for the actuators.
http://store.firgelli.com/category_s/1823.htm
They are using L-16s which are 70-80 depending on which you get so like I said not sure how I feel about the price hike.
Old 10-23-2014, 04:45 PM
  #1185
invertmast
My Feedback: (23)
invertmast's Avatar
Im planning the same upgrades for my setup and dont expect the metal nut and aluminum case to be anymore than $100-125 per pair. Skymaster seems to be gouging you guys on the actuators a bit.
The firgelli guys have actually been very open and forthcoming with info when i have asked them. My original concerns were with the plastic clevis end, they say it is designed to withstand 150lbs of force before failure, same goes for the case and internal plastic nut.
They also have said that they have only had a failure of the internal nut because of rotational twisting of the aluminum tube pushrod, so they do not recommend any twisting force on the tube. They really seem to think that an aluminum upgrade is not truly necessary.
Old 10-23-2014, 05:39 PM
  #1186
FenderBean
FenderBean's Avatar
Thanks for the info, If mine ever burn out ill just order them from firgelli direct I guess. I talked to them a few years ago and I was thinking about using them in my F-14 for the speed brakes and canopy. I will cover this in my build thread.
Old 10-23-2014, 06:05 PM
  #1187
wojtek
My Feedback: (73)
wojtek's Avatar
I would not trust the plastic end clevises especially. I use these actuators on sliding canopies, and even in this low stress application have seen these break / strip out if the actuator rod/tube. These are NOT heavy duty units at all. While Firgeli is easy to source out and apply here, I would imagine a more robust drive/actuator being desirable here ultimately. ( such as a stepper based electric drive such as employed by Behotec in their electric gear ) but this doubles or triples the cost of this function then ... Firgeli makes a great product, but i just would not use it here.
https://www.youtube.com/watch?v=0ELlFYCT1ZM
Voy
Old 10-23-2014, 06:18 PM
  #1188
FenderBean
FenderBean's Avatar
I guess time will tell, i thought about removing the actuators and using a servo on each side. I have seen a f-14 this size use a servo with some gears. Hey Jim!
Old 10-23-2014, 07:39 PM
  #1189
pilot tw
Sorry for the confusion., Because some customers possibly tigthen actuators with too much force which possibly result in plastic failure, so Likai designed new new aluminum wing actuators for options, if customers like it. We will write email to all F14 owners and ask whether they want to take this update option. we will charge the 50% cost ($ 250.- USD) for the new aluminum actuators.,
Old 10-23-2014, 07:46 PM
  #1190
FenderBean
FenderBean's Avatar
Thanks for clarifying, a simple brass bushing would prevent this. Letting owners know what to watch out for is the best way to go.
Old 10-24-2014, 01:12 AM
  #1191
invertmast
My Feedback: (23)
invertmast's Avatar
Voy
i agree, which is why all of the plastic parts are getting aluminum upgrades, ive already done the clevis ends, im just trying to find a source for the leadscrew and tap now.
Old 10-25-2014, 07:33 PM
  #1192
Caspa1
Fantastic Thomas, and great to get some 'technical' clarification on what is happening. Any chance someone can post a photo of the inside of an actuator showing what to pay attention to?
Old 11-15-2014, 10:56 AM
  #1193
Caspa1
Anyone able to let us know AUW dry and the internals for their particular config? Skymaster state 20-25kg. Have seen some as high as 28kgs dry.
Old 11-16-2014, 07:34 AM
  #1194
WimB
WimB's Avatar
mine is 28kg dry, no lead needed to balance.
2x G-Booster 15kg, all electronics and batteries in the nose.
Wim
Old 11-22-2014, 05:36 AM
  #1195
Gonzalo38
Gonzalo38's Avatar
Michel Durand from www.jetsrc.com flying his F-14. This planes is amazing. Great flyer and super stable.
http://youtu.be/Vz9XpUGmzIA
Old 11-23-2014, 09:25 AM
  #1196
muzzgail
muzzgail's Avatar
Nice video that.
Old 11-23-2014, 09:40 AM
  #1197
muzzgail
muzzgail's Avatar
Time for some photos again.
ID:	2049523   Click image for larger version
ID:	2049524   Click image for larger version
ID:	2049525   Click image for larger version
ID:	2049526   Click image for larger version
ID:	2049527   Click image for larger version
ID:	2049528   Click image for larger version
ID:	2049529   Click image for larger version
ID:	2049531   Click image for larger version
ID:	2049532   Click image for larger version
ID:	2049533   Click image for larger version
ID:	2049534   Click image for larger version
ID:	2049535   Click image for larger version
ID:	2049536   Click image for larger version
ID:	2049537   Click image for larger version
ID:	2049539   Click image for larger version
ID:	2049540   Click image for larger version
ID:	2049541   Click image for larger version
ID:	2049542   Click image for larger version
ID:	2049543   Click image for larger version
ID:	2049544   Click image for larger version
ID:	2049545   Click image for larger version
ID:	2049547   Click image for larger version
ID:	2049548   Click image for larger version
ID:	2049549   Click image for larger version
ID:	2049550   Click image for larger version
ID:	2049551   Click image for larger version
ID:	2049552   Click image for larger version
ID:	2049553   Click image for larger version
ID:	2049555   Click image for larger version
ID:	2049556   Click image for larger version
ID:	2049557   Click image for larger version
ID:	2049558   Click image for larger version
ID:	2049559   Click image for larger version
ID:	2049560   Click image for larger version
ID:	2049561   Click image for larger version
ID:	2049563   Click image for larger version
ID:	2049564   Click image for larger version
ID:	2049565   Click image for larger version
ID:	2049566   Click image for larger version
ID:	2049567   Click image for larger version
ID:	2049568   Click image for larger version
ID:	2049569   Click image for larger version
ID:	2049571   Click image for larger version
Old 11-23-2014, 09:42 AM
  #1198
afterburner
My Feedback: (18)
afterburner's Avatar
Very nice. Beautiful flying site.
Old 11-23-2014, 03:38 PM
  #1199
SStricker
SStricker's Avatar
Quick question for one of you current F-14 owners. I'm getting a foldable 4' round table. Will all three gear fit on the table?
Old 11-25-2014, 01:01 PM
  #1200
SStricker
SStricker's Avatar
Just got word it fits.
