P60/Wren 54 mount question
I have just received my Bobcat and will be fitting a Wren 54. The instructions only show options for fitting Jetcat engines. I know the 54 fits with no problem but am wondering about the height of the engine on the mount.
Is the P60 mount offset and if so, by how much?
Does anyone happen to know if the Wren 54 mount is also offset?
Thanks very much
Thanks very much
RE: P60/Wren 54 mount question
The Wren mount has roughly the same mounting holes as the P60 so it will fit just the same as using the carbon squares on the metal blocks. Fit the engine as far forward as you can
J
J
