 FLy Eagle Jet Models >
Old 07-23-2008 | 06:41 AM
  #1326
Default RE: FLy Eagle Jet Models
ORIGINAL: morro
Mate I would be very careful with this idea of where they have put the servo, I have modified mine so as the same as FLG have there's on the web site, I have seen fifst hand what flutter can do on this model, it snapped the robart hinges in half and pulled the servo out, the fin had to be replaced.
Todd
Todd,
I have decided on a HS 5245 MG for rudder. I will mount it in the fin per FE instructions.
What is FLG???
Mav
Old 07-23-2008 | 03:35 PM
  #1327
Hi Guys
My Turbine fuel pump is next to my weatronics reciever as this is the only way I can get them in the limited space available. I am worries about interferance as it is so close. Have anyone had to adopt a similar installation because of space and had no problems
Old 07-23-2008 | 08:24 PM
  #1328
Is this on the 16?
Todd
Old 07-23-2008 | 08:58 PM
  #1329
ORIGINAL: morro
Is this on the 16?
Todd
Yes the FE F16 rudder!!!
Mav
Old 07-24-2008 | 02:25 AM
  #1330
Mav I was actually replying to stonis question, sorry mate.
Todd
Old 07-24-2008 | 05:53 AM
  #1331
HI Morro
No I have the F15
Old 07-24-2008 | 05:54 AM
  #1332
Is the C/G 150mm from leading edge on the F15 with the undercarriage down or up guys? any help appreciated.
Old 07-24-2008 | 07:35 AM
  #1333
stoni1 thats a good question i have the f16 and would also like to know is that with gear up or down i guess its negligable but would like to know which way you all do it.
Rob.
Old 07-24-2008 | 10:34 AM
  #1334
you always balance with gear down unless it's a rearward retracting main gear.
Old 07-24-2008 | 10:58 AM
  #1335
thanks for that you learn something new every day here.
2 Quick questions. With the thrust tube in the f16 it is an amazingly tight fit as in denting the thrust tube a bit to get the wooden former around it has everyone else shaved a small bit off the former to get round this or just used a little brute force ?? The other one is how far from the bell mout should the turbine exhaust cone be i have the wren mw54mk3 if that matters
Cheers
Rob.
Old 07-24-2008 | 12:01 PM
  #1336
USSCAT's Avatar
Hi Rob,
I sanded the last former that goes around the pipe a bit to get a good tight slip fit. As far as the distance between the bellmouth and the engine nozel, I belive anywhere from 1/2" to 1" is desireable. For your engine I think they recommend 1" (Guys correct me if I am wrong). You mau have to cut 1/2"-1" from the inner pipe in order to get it to fit properly.
Hope that helps.
regards,
Mike
Old 07-24-2008 | 02:05 PM
  #1337
mongo's Avatar
My Feedback: (15)
while we are on this line of thought, what are some of yall doing to hold the bellmouth in place on the inner pipe?
Old 07-24-2008 | 03:07 PM
  #1338
I used a rivet gun to do mine
Old 07-24-2008 | 03:27 PM
  #1339
USSCAT's Avatar
Mongo,
I used 3 or 4 2-56 screws and nuts to secure the bellmouht. the screw head goes inside and the nuts are secured with lockwasher and loctite.
Regards,
Mike
Old 07-24-2008 | 07:07 PM
  #1340
My Feedback: (49)
...and with the UAT full.
Joe
Old 07-24-2008 | 07:09 PM
  #1341
My Feedback: (49)
I used pop rivets.
Old 07-24-2008 | 07:11 PM
  #1342
My Feedback: (49)
I have a Wren SS in mine with a 1 inch gap.
Old 07-24-2008 | 11:42 PM
  #1343
Which servos are you guys using for this jet ? I have a whole bunch of hitec digitals I usually use 5955s all around in large gassers but I'm wondering if they are overkill on this jet. Would 5645s be enough ? Would be great if someone could post a complete list of everything that is needed to get this plane in the air, servos, extensions, horns etc...
Old 07-25-2008 | 09:13 AM
  #1344
Hi Guys
I have a futaba FF9 and using a weatronics reciever... can any one tell me how to programme the brakes to come on when the gear is down and down elevator is applied?........cant think how to mix this conbination?
Old 07-25-2008 | 09:49 AM
  #1345
bug*er i have riveted the bell mouth on Mike are you saying that i should have taken an inch of that side or the rear end of the thrust tube which i could still get away with doing to get it to fit. Should the end of the thrust tube be equal length to the tail cone when it is on. or just the rear of the fuse ?
Rob.
Old 07-25-2008 | 10:23 AM
  #1346
USSCAT's Avatar
Hi Rob,
I was talking about the same side as the bellmouth. Do not change anything on the rear. I set my tube to where it is a bit sticking out of the end.
Hope that helps.
regards,
Mike
Old 07-26-2008 | 12:14 AM
  #1347
Is anyone static balancing the elevators on the JE F16, they seem very rear heavy if you dont add some weight at the LE.
Not sure if this has been asked before but the search engine fetched back a blank!
Lee
Old 07-26-2008 | 08:17 AM
  #1348
USSCAT's Avatar
Hi Lee,
I do not believe anyone as balanced the elevator. once airborne there should be no excess load on the elevator due to airflow and the shape of the elevator except when you move the stick.
Regards,
Mike
Old 07-26-2008 | 08:31 AM
  #1349
ORIGINAL: stoni1
Hi Guys
If it is like the 9CAP or 8UAP it is quite simple. Select an open mix and activate it. Select Elevator as the Master. Select your channel that you have the brake connected to as the Slave. Push the elevator stick forward to set and adjust the DOWN elevator value. Set the UP elevator value at 0. LINK and TRIM should be OFF. OFFSET should be set at 0. Now select the switch you use for the retracts. Now select the position to turn the mix ON when the retracts are down.
Jeremy
Old 07-26-2008 | 12:46 PM
  #1350
Thanks Mike
