 axel question >
axel question
axel question
Old 11-26-2007 | 06:03 PM
My Feedback: (35)
Default axel question
I am building a Facet and have Trim Accessory main wheels that have an exact ¼” axel hole. The axels that I was going to use were the dubro ¼” axels, but that are larger than ¼”. Short of drilling the wheel bushings out is there a better solution that you can think of? I think drilling the holes out will cause slop because I will never get the exact size of the dubro axel.
Your thoughts?
Scott
Old 11-26-2007 | 06:35 PM
ChrisAttebery's Avatar
My Feedback: (15)
Default RE: axel question
You need a reamer. I would chuck up the bushing in my lathe and ream them. In a pinch you could probably do it with a drill press and vice. Take them to a machine shop and ask them to do it. It shouldn't cost much.
Good luck,
Chris
Old 11-26-2007 | 08:00 PM
lov2flyrc's Avatar
My Feedback: (24)
Scott,
Do you have a micrometer to measure the axle / bushing. Dubro lists the axle as ¼” or 6.35mm, should fit without modification?
BTW, Sierra Giant makes a great set of wheels with brakes for this aircraft!
Todd
Old 11-26-2007 | 10:40 PM
Crazy4Flight's Avatar
My Feedback: (540)
Scott,
the chrome platinge probally has the axel diameter .001-.002 over size
check your email I can make it fit right
