Airworld 1/7th scale L-39 Likes/Dislikes
If you have built an flown the Airworld 1/7th Scale L-39 I would like to hear what you thought about the kit and flying qualities of the finished model. If you could list which turbine you used and the weight of the model sans fuel that would be really helpful too.
I'm thinking of building one of these to fly at my local field and would like to use Gold 44 as I want to keep the wing loading to the absolute minimum. Since this model is about the same size as the Fox Composite Hawk I would think performance would be similar.
Bob
Bob
FL
RE: Airworld 1/7th scale L-39 Likes/Dislikes
Not too discourage you from the Airworld L39, why not look into the Savex L39. The turbine of choice for the Savex is the Wren 44. It's supposed to be a brilliant jet with this powerplant.
http://www.savex.cz/
Bob
Me again!
I have an Airworld L-39 1/7th with a JetCat P80.
I would say the ideal turbine is a P60-P70 if you are going to build a scale aeroplane-ie gear doors etc.
Mine has full gear doors, legs cockpit etc.
Also my kit is an early wood lined kits and AW now use foam which tends to be lighter.
If you go wire legs and light detail I think it will fly fine on the 44 Gold
kit is basic and instructions lacking-I have notes on my web site under articles and tips from when I built my L-39
regards
Dave
Me again!
regards
Dave
Dave
I bet you'll win that bet. The power to weight of the Airworld L39 with a 44 gold will be very similiar to a Savex L39 with the original Wren 44 and mine had no problem taking off from grass. I think the Airworld L39 / 44 gold will be a very nice combination.
John
John
That is what I thought too John as I have seen the Savex model fly on both versions of the 44. The Gold powered L39 was very impressive!!
ORIGINAL: john agnew
Dave
John
Dave
John
Bob
My Savex L39 was 11lbs dry with 7.2lbs of thrust. I am sure you could build the Airworld L39 at 14 -15lbs the only difference will be the airframe weight as all of the equipment that works in the Savex version would also work in the Airworld giving you the same installation weight. 10 lbs of thrust is plenty for that weight and the model will be very nice to fly with the low wing loading.
John
John
Guys
I would guess 15-16, but that's still plenty with a 44 Gold
We flew a 15lb Panther with a Hobby Jets 632 (7lb thrust) and it was fine...
Dave
Dave
Hi,
I built and flew an Airworld 1/7th L39 for the 2007 Jet World Masters in Ireland.
I powered the plane (which was just under 9kg's) with a Wren Supersport. The model had unlimited verticals and was very slippery on landing with scale faired in flaps linkages (as i enclosed all the flap linkages internally and used 3421 JR servos....If you want to enclose the linkages and use the pre-fitted Airworld servo mounts you will need two of these servos and a way of reversing one of them...)
I lost the model on flight 3 (radio or Rx battery failure, i think no control when going downwind for landing) and the major headache is fitting the radio equipment and a full depth cockpit. Tricky and tight.
I needed no nose weight with the Supersport, Mick Reeves tailpipe and the ECU and Rx batteries mounted either side of the Nose undercarriage.
The Kit is a difficult (lots of Aeropoxy in fuselage recepticles) and a time consuming build (if you want a scale model with all linkages internal (Rudder,ailerons and flaps) and rivet panel lines in place, the Meratti/Eurokit recommended undercarriage legs are poor and prone to cracking and the Hawe retracts are not very smooth in operation. ..and for the money i think there are better, bigger and more prefinished ARTF's out there nowadays.
just my £0.02 but it's your money!
Dave Kelly Scotland
Dave Kelly Scotland
Thanks for this info, exactly what I was looking for.
Bob
Bob
ORIGINAL: Dave Kelly
Hi,
Dave Kelly Scotland
Hi,
Dave Kelly Scotland
