Pleated Paper Filter UAT Parts???
My Feedback: (85)
I want to build a "UAT" using a pleated paper filter....Can anyone tell me what part number I need for the paper filter???---Also, post some pics of the assembly as ready to install into the Nalgene type bottle and some instructions....
Thanks!!! Kevin
Thanks!!! Kevin
My Feedback: (48)
RE: Pleated Paper Filter UAT Parts???
Kevin,
Here you go. I prefer my homemade pleated filter over the conventional UAT. No need to go through an elaborate purging process to eliminate air bubbles trapped by the sock. Just fill and go.
I use the 2" Fram filter in my UAT's and use the 1" filter to make filter clunks for the fuel tank. I've used both the rectangular and round 4 oz. nalgene bottles. Fittings from Tamjets or Dreamworks. Put a piece of tygon that goes to the bottom of the bottle on your fill line so that you can also drain it completely. Do a RCU search for additional information.
Joe
Joe
My Feedback: (48)
Here's how I did it: First you remove the rubber piece from the end of the filter. Then find a wheel collar with i.d. just big enough to fit over the brass tubing. Solder the wheel collar about 1/4" from the end of the brass tube. Grind down the o.d. of the wheel collar until you get an interference fit into the hole on the end of the filter. A slight taper helps.
Force the wheel collar into the end of the filter and use JB Weld to make a fillet around it, like in the picture Mark posted. Make sure the filter and tube are straight and set it aside to cure.
Joe
Joe
