lookin for a "T" pin for a nose gear
My Feedback: (58)
WI
RE: lookin for a "T" pin for a nose gear
Yes I did try Mcmaster, Your right they do have tons of stuff. The pins that they have are not hardened or metric. Metric is not a big deal. The bushing can be drilled out to accept american. I even tried our local hardware store and the same story,,,, Not hardened
Thanks for your reply. hopefully something will come thru
Hoss
Hoss
My Feedback: (8)
I am not sure what you mean by a "T" pin but if you are talking about an axle, Dreamworks carry them (but not metric sizes).
Is this what you are looking for:
http://dreamworksrc.com/catalog/prod...roducts_id=577
My Feedback: (58)
WI
Thanks for the replys guys. If they are not hardend, I think they will bend. I should of mention that I fly off a rough grass field. Todd from Dreamworks contacted me and told me about axles that might work So Thank you Steve Collins for your suggestion
Hoss
Hoss
My Feedback: (10)
ORIGINAL: Lil Hoss
Hoss
Hoss
and use a small wheel collard to hold it.
My Feedback: (58)
WI
Sandor,, It is your jet1Agear. I am useing Feo Bao retracts in the Velox. It seems as though the pin is a 1/2 to short....... The pin through the bushing, than through the steering arm and than into the strut,,, I am a 1/2 short of hitting the set screw. AmI doing something wrong????
Hoss
Hoss
ON, CANADA
If it's just a hardened pin you need in meteric go to KBC tools and order in some metric drill rod, problably cost you about $3 for a polished 36" piece, I just ordered a whack of sizes and the stuff is beautiful.
Angus
Angus
