Reload this Page >
2008 the year of the Turbinator
Old 10-06-2015, 09:13 AM
  #376
Eaglepilot2
Eaglepilot2's Avatar
Just curious guys, Looks like Nick Ziroli has updated his website and before he had hundreds of construction photo's on the Turbinator. Anyone know what happened to those photo's and if so how to possibly access them?
Thanks!
Old 11-02-2015, 03:16 PM
  #377
yanuel
Hi, call nick costumer service number monday's, the phone number is in the website they sent my a cd with photos!
Old 11-02-2015, 05:33 PM
  #378
Eaglepilot2
Thanks Yanuel, will give them a call.
Old 11-03-2015, 03:50 AM
  #379
RAPPTOR
My Feedback: (41)
Great flyer..
Cut wing sadle out and move it back 1.5 inches.
Then wont need 2 pounds in nose.
Old 01-20-2017, 06:22 PM
  #380
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2197569   Click image for larger version
ID:	2197570   Click image for larger version
ID:	2197571   Click image for larger version
ID:	2197572   Click image for larger version
Old 01-20-2017, 06:57 PM
  #381
scootergenie
scootergenie's Avatar
Great to see you brush off the dust and continue the build !
Old 01-20-2017, 11:15 PM
  #382
CARS II
My Feedback: (7)
CARS II's Avatar
Hmmmm, I was trying to fix one or two things on my post above but all the comments got erased, not sure how, oh well.
You nailed it I dusted it off with my brush right after I took it down from the rack.
The next thing to do on the fuse is to build the vertical stab ( fun )
Old 01-21-2017, 03:01 PM
  #383
scootergenie
Oh yea, it's gonna be fun......here's mine. the real fun part is sheeting the transition from vertical to horizontal.
Old 01-21-2017, 05:08 PM
  #384
CARS II
My Feedback: (7)
CARS II's Avatar
You nailed it again
Question, how much fuel are you carrying, I was looking at the 100oz Dubro tank, comparing the the Jet Tech size with with that one, the Dubro tank is a tad longer but I think it can be made to fit the fuel tank compartment.
Three options.
[TABLE="width: 100%"]
[TR]
[TD="bgcolor: #f0f0f0"]SPECIFICATIONS[/TD]
[/TR]
[/TABLE]
Height: 96mm (3.78")
Length: 292.1mm (11.5")
Width: 130mm (5.12")
Nelgene bottle
9.5 x 5.75 x 3.25 inches
Jet Tech
10.75" (273 mm) long x 5.0" (127 mm ) wide x 4.5" (114.3 mm ) tall.
Old 01-21-2017, 05:58 PM
  #385
CARS II
My Feedback: (7)
CARS II's Avatar
After looking at the numbers I decided to try the 100oz Dubro tank, will see
Just ordered it fromTH
Old 01-22-2017, 10:22 AM
  #386
scootergenie
I'm going with the dubro tank as well.
Old 01-22-2017, 02:38 PM
  #387
CARS II
My Feedback: (7)
CARS II's Avatar
I had a chance to take some measurements, the Dubro tank will fit just fine, minor mod on BH 8, 100 oz of fuel is enough for a 10 min flight with a K 80, I may adds a small hopper tank to trap any air from going into the main tank and then there is the UAT, naah forget the hopper tank, I will just use the UAT
Specifications:
Diameter: 95.25mm ( 3-3/4" )
Length: 254mm ( 10" )
Weight: 1304g ( 2 lb. 14oz. )
Maximum RPM: up to 145000
Thrust: 8618 g @ 21.1° C. ( 19 lb. @ 70° F. )
EGT: 650° C max
Fuel consumption: 239 g / min ( 8.46 oz / min )
Fuel: Diesel, Jet A1, Kerosene
Lubrication: 5%
Maintenance cycle: 25 hr USD300
Old 01-22-2017, 04:39 PM
  #388
CARS II
My Feedback: (7)
CARS II's Avatar
Since I haven't built anything from a real kit in a long time I find myself without some of the necessary tools needed for the build, a trip to HF and HD stores will get me ready for construction .
I still have to build me sanding blocks and have to get a sheetrock for the table when I build the wings and stabs.
Everyone should have a Rambo knife
ID:	2197740   Click image for larger version
ID:	2197741   Click image for larger version
ID:	2197742   Click image for larger version
Old 01-22-2017, 05:12 PM
  #389
CARS II
My Feedback: (7)
CARS II's Avatar
It may take sometime to set up to build but it's well worth it.
Old 01-22-2017, 06:31 PM
  #390
Vincent
My Feedback: (61)
Vincent's Avatar
I put a Dubro 80oz tank in mine it fit perfect but I'm only running a 60 size motor.
Old 01-22-2017, 07:51 PM
  #391
CARS II
My Feedback: (7)
CARS II's Avatar
Im glad the 100 oz will fit, it's perfect for the K80.
First part glued, wing mout
Has anyone with a 18-20 lbs trust engine had any problems with the engine trust angle not been right?
Old 01-23-2017, 04:47 PM
  #392
csandt051196
My Feedback: (35)
Did anyone who split the wing into two pieces by chance take a picture before they sheeted it? I want to see where the tubes were installed and bracing used
thanks
scott
Old 01-23-2017, 07:52 PM
  #393
CARS II
My Feedback: (7)
CARS II's Avatar
The guys that build the 125% should be able to help you with that, the 100% are small enough that they can be carried in a small vehicle.
I believe Ron did the two piece wing on his 125%.
There, I posted a link.
http://www.rcuniverse.com/forum/rc-j...-125-size.html
Old 01-23-2017, 08:15 PM
  #394
CARS II
My Feedback: (7)
CARS II's Avatar
I read through the 16 pages and what I noticed is the lack of pictures showing details of the builds, I always like to add pictures of my builds so that it may help others building answer some of the questions they may have.
The glues that I'm using, the last two F6s didn't have the holes for the 1/4 in dowels, I used F9 to mark them and traced an F6 on 3/32 balsa in case I need them if the hatch comes out short in the back.
ID:	2197945   Click image for larger version
ID:	2197948   Click image for larger version
Old 01-23-2017, 08:37 PM
  #395
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2197950   Click image for larger version
ID:	2197951   Click image for larger version
ID:	2197952   Click image for larger version
ID:	2197953   Click image for larger version
ID:	2197954   Click image for larger version
Old 01-23-2017, 08:42 PM
  #396
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2197956   Click image for larger version
ID:	2197957   Click image for larger version
ID:	2197958   Click image for larger version
ID:	2197959   Click image for larger version
ID:	2197960   Click image for larger version
ID:	2197961   Click image for larger version
Old 01-23-2017, 11:06 PM
  #397
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2197978   Click image for larger version
Old 01-24-2017, 03:47 PM
  #398
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2198059   Click image for larger version
ID:	2198060   Click image for larger version
ID:	2198061   Click image for larger version
Old 01-24-2017, 03:48 PM
  #399
CARS II
My Feedback: (7)
CARS II's Avatar
ID:	2198063   Click image for larger version
ID:	2198064   Click image for larger version
ID:	2198065   Click image for larger version
Old 01-24-2017, 06:53 PM
  #400
scootergenie
Looking good......keep it going !
