Reload this Page >
Jetlegend 1/6 Scale F16
Old 09-03-2016, 04:51 PM
  #501
jsnipes
Originally Posted by Stevef16
I haven't and won't fly it with the ordinance Mate. As good as it would, just not interested ��
ID:	2179458   Click image for larger version
ID:	2179459   Click image for larger version
ID:	2179460   Click image for larger version
Old 09-04-2016, 01:00 PM
  #502
jeff sewell
G2 versions have a different lay-up (airex) and are significantly lighter than the G1. The U/C is also slightly redesigned, having improved damping, and more robust locking arms and it has more detail, as Scott says.
I've been flying a G2 version for about 21/2 years (same build as BVM PNP) and it's been great. I have the 1:5 scale now too...
Jeff
Old 10-04-2016, 06:23 PM
  #503
blackbirdheli
My Feedback: (114)
Maiden went great with cg set at 215mm on 10/3/16
Old 01-09-2017, 01:08 AM
  #504
Stevef16
G'day guys. Has anyone had any troubles with the gear doors pulling inwards in the air and not allowing the retracts going up. The front one is ok but the main ones get caught up. It's like the air cylinders haven't got enough strength to hold them out. I put 90/100psi
Old 01-09-2017, 04:34 AM
  #505
FalconWings
My Feedback: (57)
FalconWings's Avatar
That's a symptom of the main gear door cylinders not being located correctly. They only work correctly at one spot. I did an F-16 gear door tutorial some time ago, if I find it I'll link it.
To summarize it you need a little bit more door travel authority, which is done by moving up the cylinder rod end at the door ever slightly, which will require some adjusting of the location of the cylinder at the fuselage bulkhead in order for the door to lock tight in the closed position. This is not difficult, just undesirable on a top end ARF.
You may also try to thread out the rod end for the door to open more, but often times this leads to the door not closing properly.
David
Old 01-09-2017, 08:34 AM
  #506
gunradd
My Feedback: (9)
gunradd's Avatar
Be sure you didnt inflate the tires to much. They will do this if over inflated. The gear has been the most reliable gear I have had in any plane including sport jets.
Old 01-09-2017, 09:12 AM
  #507
FenderBean
FenderBean's Avatar
If the doors are moving causing the gear to hang you may want to address that issue to fix this. Check your mounts for the air cylinders. If they are not flexing then you need a stronger cylinder to prevent them moving. I had this issue on my f-16 which had two problems first was the mounts which I fixed with some thin ply and then an alignment issue, if mounts and cylinders are not the problem check over all gear alignment or over tire inflation. The bulkhead was of a couple mm which would cause the hang if I put air in the tires.
Old 04-18-2017, 04:34 PM
  #508
blackbirdheli
My Feedback: (114)
Default V1 vs V2
Is the V2 fuselage a piece fuselage joined at the back of the cockpit area? Visually. How and you tell if it's V1 or V2? Thanks
Old 03-18-2021, 05:01 PM
  #509
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Bypass or no bypass?, that is the question...with a K180 too boot..
Old 03-18-2021, 10:09 PM
  #510
andretorres89
andretorres89's Avatar
i have just the bottom half on mine with a 170. Works great that way
Old 03-19-2021, 11:58 AM
  #511
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
I'm realizing my big bell mouth pipe won't work with this bypass..I see most have normal lipped pipe..
