4th gen A-10 by Mibo jets
#751
My Feedback: (61)
TX
RE: 4th gen A-10 by Mibo jets
ORIGINAL: ChrisPetersen
I received my fans yesterday from Roger!! They seem like a pretty slick set up. The four bolts that hold the turbine assembly in place secure a metal bracket with a shaft that the fan rides on. Each fan has dual bearings and spins quite easily. I blasted it with air from my compressor and it spun up insanely fast with no vibration.
My only gripe is they are extremely rough finish from being made on a 3d printer. I am a little uncertain what color to paint them.
could you possibly dye them a grey color with rit dye and hot water? done that to nylon quite a bit.
i have a 3D printer in my shop that uses the same ABS that Mibo prints with (as far as i can tell from my LG parts that are printed also)
i can send you a bunch of ABS print stock you can experiment with if you want. the stuff is like fishing line, but ABS and a natural off white / cream color.
Kirk
#752
ID
Mark, I'm still here,
Just having a few e-mail issues again with my server.
My phone works great though!
I already spoke wiht Heraldo. Mark...Your stuff will be done tomorrow.
Dan
Dan
#755
A video of the HAWG at LeLuc Air Force Base.
http://www.youtube.com/watch?v=eRmF1...1&feature=plcp
#757
Hello Stan as usual amazing plane and very beautiful Airfield.
I hope Christophe will make a little meeting at LELUC in 2013.
Best regards.
PS:I phone you As soon as I know the date for the first fly of the P47.
Best regards.
#762
Yes I use the fans on my A-10 so far working great http://www.youtube.com/watch?v=d4VeUA4WUDQ
#763
Thank you, Anurag, Fifou, Craig and Frankie for your compliments.
For the time beeing I'm still pneumatic as it works smooth. But I use "non-symetrical" air restrictors to slow the lowering of the wheels in order to avoid to slam them when ordering the gear down.
It could be interresting to transform the brakes into electric.
Have a look at GBRJets ( UK ) or request Geir Flesche an address.
I just finish to test the dummy turbo-fans on my A10. The effect is absolutely fantastic. They add a lot of drag, really. But the power of the 2 P160 are copping easily with that.
Next step : DECELERONS !
Best regards
Stan
Best regards
Stan
#764
Short video of my turbo-fan on ground
http://www.youtube.com/watch?v=sqbP7...ature=youtu.be
#765
Hello Guys,
someone find a solution for the small main gear door which is glued to the leg in combination with the new Behotec retract?
The new leg with the Behotec retract is in my opinion round about 1cm too high over the wing surface, so the door doesn´t fit.
regards
Joerg
regards
Joerg
#767
My Feedback: (61)
TX
ORIGINAL: Inconel
Hello Guys,
regards
Joerg
Hello Guys,
regards
Joerg
#768
My Feedback: (61)
TX
ORIGINAL: Inconel
Hello Guys,
regards
Joerg
Hello Guys,
regards
Joerg
the wood shim is required between the rear retract bolts and the wing lower surface......this may be your issue with the small forward door fitting, if you do not have the shim in place. this would cause the leg to sit too high up front, when retracted.
#770
My Feedback: (61)
TX
ORIGINAL: Inconel
you mean this wood piece? It´s really thick...
direct unter the rear gear retract bolts?
this positions the gear correctly in the well, and all the doors fit. you will need to clearance the large hinged door's inner skin as said earlyer.
#772
My Feedback: (61)
TX
ORIGINAL: Inconel
ok, f*ck [:@]
have always glued the middle door to the leg.... [:@][:@]
ok, f*ck [:@]
I hit many of these issues... that is the problem with a plane and NO instructions. thank goodness for this thread and the limited instructions on the jetadic site thet Keith wrote (and a few phone calls to Chris )
good luck with the re-work.
#774
My Feedback: (35)
A MESSAGE FROM BOGO......"HUMMMMM BE CAREFUL"
I'M NOT SURE OF THE INTENT MAYBE POPEYE THE SAILOR ARMS OR THE INCREDIBLE SLOVENIAN HULK !!!
PROBABLY QUARTER SCALE HAWG TIME HUH ???
