...carbon spar??
My Feedback: (23)
hello gent's
i need to make a conection stronger
and the first idea was a carbon tube with the two phenolik for each side to run in
...but i run out of space so
i noticed in comp.arfs giants have spars to join the wings
..... since aluminium spar would be heavy... is there any sorse links to carbon spars?
i am interesting for a 60cm lenth to 5cm or 6cm to 1cm wide...
thanx in advance for any replyes!
These guys have a nice selection, and you can find tube OD/ID that nest so you can build a semi-tappered spar!
http://www.acp-composites.com/
