Reaction ARF - PST/BTE All-Composite Sport Jet
#828
RE: Reaction ARF - PST/BTE All-Composite Sport Jet
ORIGINAL: skywarrior
Hi,
might be interested in a T37 as well. more info required if true please.
regards
David
Hi,
regards
David
http://www.pstjets.com/PST%20Web.files/Page1181.htm
This is a Master 1/3 Scale ARF and will be offered as a complete kit. PST will make official announcement when we have more flights with the prototypes.
Cheers,
B777
#830
Hi all,
RCISFUN, Wow, what happened to that ??? Is the main fuz the only damaged part ???
your doing a great job to put her back together... bit like humpty dumpty fell of the wall !!!
Whats your turbine there ???
Keep us posted... cheers Jeremy.
#831
My Feedback: (44)
Hello Jeremy,
I pick this up at FL Jets this past March after the original owner had a minor landing mishap. [X(][X(]
Yes the rear section of the main fuselage took the brunt of the crash damage, also the clear canopy and the right wing tip.
The wing is now repaired; however, the live hinge for the aileron has been damage beyond repair so I removed the surface and have to decide if I want to repair with robart hing points or re-make a live hinge using the CA type of hinge material.
Got to love fiberglass fuselages...so easy to repair!
Turbine is a Jet Central Super Eagle...it should push it along
#832
Hi back Rich,
Minor mishap !!! lol, that would be a writoff for me... good on you for having the patience to rebuild her...
That JC Super Eagle should do the trick, cool... Keep the info coming, and all the best...
Jeremy.
Jeremy.
#834
My Feedback: (44)
Maybe this has been already mentioned...although I didn't see it.
Anyhow it deals with the removable Stab and Fin assembly on the Reaction X.
If you follow the plan you would route your servo wire down through the stab....this doesn't make sense as it defeats the removable stab feature unless you remove the fin...which would entail removing the heat shield and hatch cover to gain access to the front fin stud and nut attachment point.
As I don't want to have to remove the fin I came up with an alternate servo lead routing.
My solution was to drill an internal hole in the fin to allow the servo lead to route to the front of the fin where there is an access hole right behind the stud. I then routed a slotted hole in the fuselage to allow the servo lead access.
Now I can remove the stab by sliding back to disengage the pins then slide side ways to remove without touching the fin.
#837
Hi Rich,
Your pics of the painted fuz look great, wouldnt know its been broken... Now your post on Tailplane and fin removal...
The Fin has a aluminium tube, which plugs down thru the stab, into a alum socket, plus the stud and nut at the front end...
So that would stop one from sliding the stab out, leaving behind the fin !!! Do you not have the Alum Tube ???
If not, then there is not much to support your fin...
Regards Jeremy.
Regards Jeremy.
#838
My Feedback: (44)
Jeremy,
The Alum Tube and socket are just in front of where the stab keys into the fuselage so the fin does not capture the stab, at least it is that way on my X version which was built at the factory sometime after October 2009., see photo.
This is why I was wondering why the factory would route the servo lead through the stab, it defeated the purpose of making it easily removable.
#840
Hi Rich,
Yea your rite there, my BAD... Makes sence then to move the servo lead out to the front, good idea...
Servo down the back is also good, only downside is moving more weight aft, but on the X version not so bad...
What did you end up doing to fix your wing hinge you mentioned ???
When you think its going to fly ???
Jeremy.
Jeremy.
#841
My Feedback: (44)
Jeremy
I used Robart Hinge points, I used Hysol to glue in doubler blocks on the trailing edge of the wing.
I hope to fly within the next two weeks, I ordered some parts today from Dreamworks as soon as I get them I will be real close to completion.
#843
RCISFUN, Hi,
Looking awsum, you done a great job of putting it back together, and the paint job to...
What sort of crash did it have to break up like that, cartweel maybe ??? Given your rebuild, do you have any suggestions,
As to areas inside the fuz, that could do with some extra glass for strength ??? Im at that stage with my build rite now, just looking to see if i should
put some more glass cloth around...
Cheers Jeremy.
Cheers Jeremy.
#844
My Feedback: (44)
Hello Jeremy,
I didn't see the crash...only afterwords, I have been told it bounced off of a tent before hitting the ground.[X(]
I was thinking exactly the same thing, what are the odds of only breaking the rear section, the canopy and one wing tip.
I don't think you need to beef up anything...building for crash is not a good idea
She is a bit porky now, it weigh 29 LBS dry, so I guess I gained about 3 LBS with the repair and paint.[X(][X(][X(]
However I don't think it will care with a Jet Central Super Eagle in it
#846
Rich Hi,
Bounced off a Tent !!! Wow, whats it doing near them in the first place !!!
Ok sounds good, yea i agree building for a crash isnt so good, thanks for sharing... Dont think your weight will be a problem,
everyone Raves over how good the wing lift is, and 26 to 28lb seem the norm... ENJOY, Keep us posted on how the maiden goes...
PS, Have you got any inside instal pics you care to share ???
Cheers Jeremy.
Cheers Jeremy.
#847
My Feedback: (44)
Jeremy,
The tent was behind the flight line at a jet rally..... a high gusting cross wind happened around the same time as the landing approach and the rest is history[X(]
Here are a couple of photos of the install, I still need to make my tray graphics.
The Du-Bro 32 oz tank will be for my smoke system when i install it.
The plane came with the big 3.8 L (128 oz) main tank which feeds the air trap
#848
Rich Hi,
Looking good there, thanks Heaps for posting your instal pics, Good luck for your Maiden, Keep us posted...
Cheers Jeremy.
Cheers Jeremy.
#849
Hi all...
Been VERY Quiet on here lately, whats everyone up to ???
RCISFUN, Rich, you done your maiden yet, How is it ???
PST, Whats happened to the Re Vision ???
Cheers Jeremy.
Cheers Jeremy.
#850
