Reload this Page >
Reaction ARF - PST/BTE All-Composite Sport Jet
Old 02-15-2016, 04:38 PM
  #1101
Toolbag
Toolbag's Avatar
Originally Posted by rcjets_63
I have 75 degrees of flap for landing my long nose Reaction. I recently added 3/16" of crow (up aileron) with landing flaps. It makes the plane even more predictable in landing and reduces the floating. Give it a try.
Other recent modifications include a new component board mounted low and replacing the nose wheel steering servo mount, a dual nose wheel, and the forward search radar blister under the nose, and I finally started the mold for the anhedral stab.
Jim
Nice addition with the radar blister.
I will try the crow set up - I already have this set up on my radio I just have to throw the switch - will try it next time.
TBag.
Old 02-15-2016, 05:06 PM
  #1102
Harvey Mushman
My Feedback: (10)
Jim
Jim,
Now that I see your photos I realize I met you at the Coachella Jet Jam a week ago. I also spotted for you a couple of flights.
I'm in the process of correcting the turbine mounting plates and will set them at 15 degrees down in relation to the top of fuse.
BTW all, Jim is a very good pilot and flew his Reaction really well at the Jet Jam. Can't wait to get mine completed.
Bob
Old 02-16-2016, 12:54 AM
  #1103
Toolbag
Toolbag's Avatar
Bob you must take a video of your maiden.
Old 02-16-2016, 02:11 PM
  #1104
rcjets_63
rcjets_63's Avatar
Hi Bob,
It was great to meet you and thanks for spotting for me. I hope you have as much fun with your Reaction as I'm having with mine.
Jim
Old 02-20-2016, 09:46 PM
  #1105
Toolbag
Toolbag's Avatar
Well I did the crow addition to 3 flights yesterday - landings actually. It does slow it down a little more and is more stable but I found it takes more elevator to make it flare a few more flights will get me better dialed into the landings.
I just recently installed live airspeed telemetry activated by throwing the landing gear switch, nice addition with voice feedback telling me IAS on approach, I did notice with the crow added it doesn't allow the model to accelerate as much during final decent onto the strip slowing it down more, it still gains airspeed during steep descent at our field but not as much.
John
Old 02-20-2016, 10:00 PM
  #1106
Harvey Mushman
My Feedback: (10)
John
John, sounds like crow helps. How much crow are you using? Jim said he uses 3/16". I'll add crow to mine as well, maybe starting with a small amount and then adding more as needed.
Bob
Old 02-21-2016, 06:59 AM
  #1107
Toolbag
Toolbag's Avatar
Bob
I also started with 3/16" but I found that towards the end of the approach the model wouldn't descend/sink so I must add in a little more I would now start at 1/4" next time and add a little more down elevator to 1/8" down. Whilst the setup didn't allow the model to gain as much airspeed on descent (braking effect was better than with flaps only) it wouldn't sink when in level flight during the final stage of approach requiring slightly more down elevator to compensate.
John
Old 02-21-2016, 11:00 AM
  #1108
Harvey Mushman
My Feedback: (10)
Bob
John
Thanks for the info. It will definitely help me get my Reaction dialed in.
Old 05-30-2016, 12:10 PM
  #1109
rcjets_63
rcjets_63's Avatar
I finally got around to molding the anhedral stab for my Phantom Reaction. For those interested in how to mold parts, here are some pics.
I had bought a stab from the factory to use as a plug. It was a custom order in that the elevator had not been cut/slotted. The stab was cut into three pieces (left stab, center section, right stab) and then I sanded the mating surfaces at a 10 degree angle using a table sander. The three pieces were glued together to give 20 degrees of anhedral to each half of the stab. The joints were then puttied and sanded, and the entire plug was and wet sanded smooth. This completed the "plug".
Next I went down to Lowes and bought a 2'x4' section of whiteboard (about $10) and a hot glue gun. I cut a few strips of whiteboard about 2-1/2" wide to use as the mold parting plane. These were hot glued to the edges of the plug such that the white surface was on the seam. I find it is easiest to build up "globs" of hot glue on the back (non-white) surface of the whiteboard.
I never manage to get the joints to be a perfect fit, so a bit of sanding is done to blend the joints.
You can see in the photo that there are some small gaps between the edge of the whiteboard and the edge of the stab. This is typical at curved areas such as the wingtips or, as per the photo above, at the transition to the center section. These gaps are filled in with children's molding clay (available from an arts and craft store such as Michael's). Kneed the clay to warm/soften it and then roll it into a long roll then lay it along the joint between the wood and the plug. Push the clay into the gap then use a small putty knife or spatula to cut away the excess.
Next, apply some silicon pads to the parting plane to serve as locating "pins". Use clear parcel tape to tape over any areas of the parting plane that you sanded (I forgot to do this, D-oh!) to seal the sanded surface. Then spray the plug and parting plane with mold release (which gives it a blue/green shade).
Next, cut the fiberglass cloth. I cut the cloth to cover one half of the plug (with enough to overlap a couple of inches at the center). I cut enough for one layer of 3/4 oz, two layers of 4 oz, and 5 layers of 10 oz (total about 60 oz stack-up). A roller cutter (available from a sewing store like Joanne's Fabrics) makes the job a lot faster. You can also use a cutting mat (to prevent dulling the blade), but I cut on a plastic topped table which seems to do a good job preserving the blade and I don't have to fuss with putting the cloth on a cutting mat.
Next, mix up some resin and micro-balloons to form a slurry. Use enough micro-balloons that the mixture is thick enough so that it doesn't run (like the icing for a cake). Use paper to make a pastry bag (https://www.youtube.com/watch?v=tdrgGGR4txc) and fill it with the slurry. Squeeze a bead of the slurry around the outside of the stab and around the silicon bumpers. The slurry is used to fill in these areas otherwise you will tend to get voids in the mold as the glass cloth will not get into the corners. Sorry, I forgot to take a picture.
Next lay the 3/4 oz glass cloth over the plug/parting plane and use a disposable 1" paint brush to brush on the resin. You want to completely saturate the cloth over the plug and over the parting plane. Be gentle to not pull the cloth away from the transition between the plug and the whiteboard. The photo below was taken after the 3/4 oz layer was applied and I have just laid the first piece of 4oz on top of the left side. You can just see the white slurry around the stab & bumpers around the right side of the stab.
I use West Systems resin/hardener with the pump fittings. This lets me quickly mix up a little bit of resin at a time (4 pumps of each). If I mixed any more, it would start to cure in the cup (it was about 90 degrees in my garage in Phoenix when I laid up the mold). Mix a bit, apply the cloth, mix a bit more, etc. Once all the layers are applied, let it cure overnight.
Next, I used a Dremel with a cutoff wheel to trim the edges of the cloth even with the parting plane.
Next, flip the stab over and CAREFULLY use a chisel to cut away the beads of hot glue. The glue should pull away from the plug without leaving a residue or damaging the plug (unless the chisel slips, as it did for me, Double D-oh!). If it slips, fix the blemish with some spot putty, sand smooth, and locally re-prime.
Regards,
Jim
ID:	2165064   Click image for larger version
ID:	2165065   Click image for larger version
ID:	2165066   Click image for larger version
ID:	2165067   Click image for larger version
ID:	2165068   Click image for larger version
ID:	2165069   Click image for larger version
ID:	2165070   Click image for larger version
ID:	2165082   Click image for larger version
ID:	2165099   Click image for larger version
ID:	2165101   Click image for larger version
ID:	2165102   Click image for larger version
Old 05-31-2016, 09:47 AM
  #1110
rcjets_63
rcjets_63's Avatar
More work on the anhedral stab mold. I fixed the blemishes in the underside of the stab, then laid up the lower mold using the same technique as given above.
Regards,
Jim
ID:	2165261   Click image for larger version
Old 05-31-2016, 07:10 PM
  #1111
rcjets_63
rcjets_63's Avatar
Finishing off the stab mold. Once the resin cured for the bottom half of the mold, I simply trimmed the excess material around the periphery. Holes are then drilled around the flange to enable the halves to be accurately bolted together later. Then, the best part....opening the mold....it's like Christmas morning :-) Carefully slide a putty knife along the split line between the mold halves. Work all around the periphery and then flex the putty knife carefully to distort the mold slightly to release the mold from the part. This can take some patience so you don't damage the mold or the plug.
Once one side pops free, gently distort the other side of the mold and pull the part free. You can also inject some compressed air between the mold and the part to help it release. Once the part pops out, clean the mold with water to dissolve the mold release you sprayed on earlier. Inspect the mold for any issues, bubbles, etc. You should easily be able to see any panel or scribe lines on the part have been captured in the mold. Bolt the halves together for safekeeping and to prevent distortion.
Regards,
Jim
ID:	2165353   Click image for larger version
Old 06-01-2016, 08:56 AM
  #1112
redtail
My Feedback: (15)
redtail's Avatar
Jim - other than my love for the F-4 and inspiration by you as being identified as one who was building an anhedral tail, I may not have decided to bash the perfect kit that Bruce designed. View the (Reaction 54 Jet Kit - build thread under JETS here on RCU, to see how I built the wood vs fiberglass tail feathers). Build is covered on the following pages/posts: Pg 136 - Post 2288 -91. Pg 139 - Post 3462, and finally, Pg 141 - Post 3505. All parts have been primed, now sanding the wings/fuse. Painting is close. Your workmanship is skillful. Enjoyed the write-up. Will be useful for a future project. Thanks. Chic
Old 06-03-2016, 07:04 AM
  #1113
BruceTharpe
BruceTharpe's Avatar
Jim, that's a terrific tutorial, but I think you're reaching a very limited audience. I think you should start a new thread so it can be shared with the entire jet community.
Old 06-13-2016, 09:41 AM
  #1114
rcjets_63
rcjets_63's Avatar
Thanks for the comments. I will probably do a new thread for molding my B-58 Hustler, but this is just a minor effort to document the anheadral H-stab.
Now that the upper an lower molds are done, it's time to actually start laying up the real (flying) parts. The molds are first sprayed with a thin and a thicker coat of mold release and allowed to dry. Next, a mixture of resin and micro-balloons is added to the tight corners in the mold.
A layer of thin (3/4oz to 2 oz) glass cloth is next laid in the mold and worked into the corners using a resin-filled paint brush to eliminate air bubbles. A second layer of cloth (4 oz) is added and then I put on a layer of carbon fiber to reinforce the center section where the spars will be installed.
A layer of peel-ply (yellow) and breather cloth (white) is added over the layup. I use ripstop nylon purchased from Joanne's Fabrics as a peel ply; it cost about $5.99 per running yard (2 sq yards) and there is usually a coupon in the Sunday paper for 20% off any item. The purpose of the peel ply is to soak up excess resin and allow the gloss hard surface of the cured epoxy to form on top of the ply. After the epoxy has cured, the ply is manually peeled away leaving a remaining surface that requires little/no sanding before the next step. The breather cloth allows air to be pulled away from all regions of the part during the vacuuming.
A few strips of flash tape are added to hold everything roughly in place while the mold is inserted into a vacuum bag. I used a 24" wide "infinite tube" bag cut to length (about 30" long) which only requires the ends to be sealed. The vacuum fitting is added to the bag (over a few layers of breather cloth) and the end of the bag is then sealed.
Applying the vacuum pulls everything down against the mold. The layups for the upper and lower skins are shown in the pics below.
Next is the fun part....After the resin has fully cured, GENTLEY peel away the peel ply. Some resin may have soaked into the breather cloth so the peeling may take some force. A bit of local sanding may be required where there were creases in the peel ply.
The next step is to cut out the core material which will be added to the upper an lower skins. Typically I'd use .060" thick foam but I had some extra .090" thick sheets for the B-58 project. The core is cut to shape so that it fits inside the mold (comes about 1/4" inside the periphery of the mold. The three slots in the center are for the spar reinforcements (to be added later) while the cutouts around the elevators are for the balsa frames to be added around the elevators.
Regards,
Jim
ID:	2167680   Click image for larger version
ID:	2167681   Click image for larger version
ID:	2167682   Click image for larger version
ID:	2167683   Click image for larger version
ID:	2167684   Click image for larger version
ID:	2167685   Click image for larger version
ID:	2167686   Click image for larger version
ID:	2167688   Click image for larger version
ID:	2167689   Click image for larger version
Old 07-11-2016, 11:59 AM
  #1115
Toolbag
Toolbag's Avatar
Recent images taken from our strip in Southern Queensland.
Old 07-11-2016, 12:00 PM
  #1116
Toolbag
Toolbag's Avatar
This one I like.
Old 07-11-2016, 05:59 PM
  #1117
Harvey Mushman
My Feedback: (10)
Looking good John!!!
Old 08-12-2016, 03:10 PM
  #1118
Harvey Mushman
My Feedback: (10)
Jim, your anhedral tail looks like it will be very strong. Nice work!
Bob
Old 08-15-2016, 09:09 PM
  #1119
Harvey Mushman
My Feedback: (10)
My short nose is almost ready to maiden, just have to finish canopy/cockpit. My total weight with empty fuel tank (except UAT is full) is 28 pounds. I'm curious what others weigh and I don't want go back through all the posts again, so please let me know what your R weighs. I've seen 26 and 31 lbs. so far, so if those are typical then it looks like I'm in the middle.
Bob
Here's a couple of pics of fuse outside and inside:
ID:	2177126   Click image for larger version
Old 08-15-2016, 11:36 PM
  #1120
paulsf86
My Feedback: (52)
My short nose weighs in at about 28 lbs and is very comfortable with a Jetcat P70. Lots of fun and relaxing to fly.
Good looking scheme and installation. Mine is very similar with T45 markings.
Paul
Old 08-16-2016, 08:17 AM
  #1121
Harvey Mushman
My Feedback: (10)
Thank you Paul!
Are you going to Best In The West this year?
Bob M
Old 09-18-2016, 09:12 AM
  #1122
Harvey Mushman
My Feedback: (10)
Finally done and ready for maiden at BITW.
ID:	2181399   Click image for larger version
ID:	2181400   Click image for larger version
Old 09-18-2016, 02:37 PM
  #1123
Toolbag
Toolbag's Avatar
Havey - what a great job you have done - looking really good - you must be pleased - any video yet.
Old 09-18-2016, 04:30 PM
  #1124
Harvey Mushman
My Feedback: (10)
Thank you! Hasn't flown yet so no flight video. Will maiden at Best In The West in 2 weeks.
Old 09-20-2016, 03:22 AM
  #1125
Bryan McLarty
Bryan McLarty's Avatar
Looks great, Harvey! Can you tell me where a young man would buy one of these? I got mine from Bruce Thorpe Engineering and believe they aren't a US distributor any longer.
Love mine!
