composite-arf......querry
Hi all,
I have a querry about the material used to build the jet fuselages by manufacturers like www.composite-arf.com or www.asiascalerc.com
what does ARF stand for ?..is it (aramid reinforced fibre ) or normal Fibre Glass ?
My Feedback: (24)
Most of the composite aircraft are standard fiberglass and epoxy resin. Carbon fiber is used in areas where extra strength is required and in the flying surfaces, a sandwich of fiberglass and foam is used for greater strength-to-weight ratio. I'm not sure if manufacturers use fibers like Kevlar (actually a para-aramid) in their layups for aircraft parts - except fuel tanks and I think the greatest benefit in fuel tanks is that it looks cool...
Bob
Bob
Thanks a lot guys...
that solved my query.
I had been to the anual aeromodellars meet in India 2 days back & there I got to see these jets ...wow!..they all were amazing flying at 350kmph. I also saw an unfortunate Bobcat jet crash which was flying low to the runway when it just rammed into the ground due to the rear wing breaking off in mid-flight ...& the debrie was all over the runway. The turbine engine was smashed flat on one side[&o]..it was sad to see that happen....but thts part of the game & Jets are way too Kool!!..
that solved my query.I had been to the anual aeromodellars meet in India 2 days back & there I got to see these jets ...wow!..they all were amazing flying at 350kmph. I also saw an unfortunate Bobcat jet crash which was flying low to the runway when it just rammed into the ground due to the rear wing breaking off in mid-flight ...& the debrie was all over the runway. The turbine engine was smashed flat on one side[&o]..it was sad to see that happen....but thts part of the game & Jets are way too Kool!!..
