Skymaster plus 1:5.5 BAE Hawk
#201
My Feedback: (23)
RE: Skymaster plus 1:5.5 BAE Hawk
ORIGINAL: Top Buns 2006
whats up with the horrible geometry on the nose gear steering?? 3 rd photo post 191.... is there a reason for this??
not horrible at all! it works great!
the reason is the plastick conector.it is offset! this is why it calls for this set up.and becouse of the offset the geometry is corect!
if you have a set avaliable give it a try!
#202
your still not at 90 and 90. Im betting it turns sharper one direction with equal servo travels.
Why is it criss-crossing anyways, why not straight?
Why use such a long servo arm? Isnt it better to have a short servo arm and run your ATV's at 100% or greater?
#203
Hi!
Can anyone help me...
I have the old hawk, and are now (trying) to install the engine. The mounts on my merlin 90 are in the center of the turbine.
So then the turbine have to be liftet up a bit ? use the 2 wodden blocks that says "for jetcat 120".
Thomas
#205
My Feedback: (23)
your still not at 90 and 90. Im betting it turns sharper one direction with equal servo travels. you are right .there is no need for equal servo travels since you can reduse end points.
you also need to add expo to soften the stering.so this is not a heli pich servo set up. we dont care if servo will travel faster to one direction than the other to get the same degrees.
with the reduse end points and the expo needed you will never notice this.
Why is it criss-crossing anyways, why not straight?thatwould be great !but 1-wont clear doors and opening for retracting 2-with equal servo travels you dont get equal stering travels becouse of the offset mount i mention above
"been there try that" no its not better becouse of the nature of the offset hole..resolution is still good with this set up dont worry/we own the stering retract unit.feel free if you own one of this units to set up 90/90 degrees smaller arm and come up with photos and resolts.
...my 2c //
#206
Hi
In my Hawk I have the nose wheel steering pushrod straight. I don´t have any problems with the doors (2 doors in the nose) opening or closing an I have peace of mind that the geometry of the pushrod is better. In any case you are right that with your setup you get enough travel to do the job adjusting asimetrical end points and expo.
Regards
Eduardo
#211
I exchanged K-80E to P-120. The P-120 is not stable as K-80E when I slow pass the runway.
The fuel consumption at 1.6 L for P-120 can fly 5 min, for K-80E can over 8.5 min.
Photo and Video by : Tony5548
[youtube]http://www.youtube.com/watch?v=Gc4kFXvSJhE&feature=player_embedded[/youtube]
#216
My Feedback: (23)
hello guys!
..i had a Hawk seating in my lab for some time ..and i desided to build it now i had vecations..in a week time it was ready but no time for painting..so i add some stikers and off to fly
what an easy jet to cruising around the sky!i loved the knifes and its big wingspan! did try flaps and it gets realy slow!
i got them mixedout with elevator but for start my landings where no flap.better hot than crashed
not the best quality but its somethink[&o]
this is the secont flite after the short maiden for triming out..
thank you for waching[8D]
[youtube]http://www.youtube.com/watch?v=FgB7Rw7NOFY[/youtube]
#221
Hi Guys, is it true that the BAE Hawks are prone to getting rudder flutter?
what kind of rudder servos are you guys having success with-
Thankyou
Ants
Thankyou
Ants
#222
My Feedback: (23)
from my expirience no.
i have hard flew 3 of them till now.
all got a hitec 5645 mg on the rudder. ...point rolls .. knifes ... no promblem what so ever
the fin on the hawk has a very good stracture and no flexibility
i got a p160 on mine and fly it with proper throtle managment..
thats not a speed frame
my 2c
my 2c
#224
ORIGINAL: Ayrtonsenna
Thankyou
Ants
Thankyou
Ants
also mine with hitec 5645mgi attach photos of my setup..never heared from other owners about rudder flutter
#225
My Feedback: (10)
You sly bugger! never told me you had a Hawk ! Nice one.
What sort of diameter lens do ya need? Thought of dealing to a cheap torch to make it fit.
