midwest he-162
hey frank99, i just so happen to have a turbax 1 fan and kb 7.5 with macs pipe for sale. engine and fan never run and pipe nib. email me for more info if you want. [email protected] thanks, doug
Doug,
Which 7.5 engine do you have? FIRE or RIRE? If RIRE, which carb?
He162 is a good flier with that setup. I've seen several.
Larry
[email protected]
Larry
[email protected]
My Feedback: (29)
g man the old set had the tank in line with the fan in the rear everything was hard thr. tank etc might try to restore my with all new now sure on the tank and so forth for new equipment can you send me a pic of yours my is in need of restored, framed and painted did not know mono kote and modeling in general at the time
Frank,
The OS .46FX is not a D/F engine; won't work with side exhaust. YOu need a ducted fan engine if you want it to get out of its own way!
Larry
[email protected]
Larry
[email protected]
My Feedback: (61)
G-Man,
I mounted the tank in the fuse per the plans but use a perry pump on the OS-46. The round perry pump?? It required a pressure tap on the motor crankcase, it worked beautifully, the motor would idle forever and run up perfect. Thrown rod finally bit me, ended up in a tree.
Vin...
Vin...
my engine is the fire, perry pump and carb. its never been run. not a drop of fuel. fan is new also. i want to sell it to get a bigger fan and engine for my a4 skyhawk.
