new jet-tronic valve
FL
I just recieved the new jet tronic valve and it comes with the old directions. This one has four fitings to plug into. they call it a doulble valve. The bottom housing is white plastic or something. I am using it for my speed brake that needs to release pressure when I turn it off in order to get to my on/ off switch ect. How do I plumb this?? Thanks Bill Squillace
RE: new jet-tronic valve
Bill
There should be a piece of paper which has numbers on the port openings that correspond with the original instructions (also numbered)
The two nipple opposite the buttons (side by side level) are the outputs (up/down)
The two at an angle are inlet (higher one) and exhaust (lower)
regards
Dave Wilshere
regards
Dave Wilshere
