Boomerang Sprint Build Thread!
#52
My Feedback: (10)
RE: Boomerang Sprint Build Thread!
ORIGINAL: volkan
A bit more done today, the gear is surprisingly easy to install! Only think to mention is that you will need countersunk screws in order for the top CF plate to fit... right sandor?
Also got the fuel tank today, which slips right into the fuz, absolutely perfect fit!
i thought there was sufficient space for those.
will fix that anyway
#53
My Feedback: (10)
if anyone has a question about using spacers?
i was reading this:
Quote"best to manufacture a nose strut specific for the Sprint to eliminate any need for spacer blocks and to get the stance correct."
1 .well there is no room , the retract is as far forward as possible , the wheel touches allready the servo bay therfore you must get a offset.
that is why we supply for free the "raisers"..
2 .steering rods , there is not sufficient place to use the steering rod to collapse all the way down.
3. boomerangs Hate to take off in a negative angle of attack , i flew all of them.
4 . we designed it so that both the front and the main oleo,s can be swapped for even the 40LBS oleo,s.
wich for the USA market (Smoke tank-1 gallon fuel - P120se-titan) will like.
our special made Kingcat oleo,s will fit the Sprint also.
i was reading this:
#54
Hi buckerboy,
My club mate found these people that make sheets that you put into your printer (either get the inkjet or laser ones to suit your printer), then make your own decals.
he has used this and made some nice decals of our club badge.
Hope this helps.
http://www.craftycomputerpaper.co.uk...D=158&CatID=15
Hope this helps.
#55
Yes, that is our same 125 ounce (3.7 Litres) custom made Sullivan fuel tank as used in the Sprint, the Elan and also fits the XL with a tiny modification to a former.
Gives you the option to have any flight time from 5 minutes up to over 15 minutes. Just fill to the level you want.
Alan.
Alan.
#56
My Feedback: (36)
AR
Hello Alan
Any chance you will sell the sprint in a kit version for those of us who like to build. I get a lot of enjoyment from building and would love to build one from a kit and since it’s a balsa and ply plane with a little bit of fiberglass seems it would lend itself to kit form rather easily but I don’t know the logistics or costs associated in gathering all the pcs together and putting it in a kit. I plan on purchasing a arf from Patricia some time in the near future but I sure would like a kit version also. Food for thought.
Thanks, Neal
Thanks, Neal
#58
Done a bit more in the past few days. The MASSIVE intakes are in and the model is now on its wheels. Just waiting for some bits and pieces to finally finish of the model. Fitting the retracts were quite easy, no major modification required.
#59
Almost done!
Few more pictures of the final install, hope to have the model put together tomorrow. After that its just the radio and linkage setup.
#62
My Feedback: (36)
AR
What is the max wheel size diameter the wheel wells will take for the main wheels? On the digitech nose wheel strut what is the max wheel diameter usable on it.
Thanks, Neal
Thanks, Neal
#63
My Feedback: (10)
ORIGINAL: Undecided
Thanks, Neal
Thanks, Neal
Nose wheel strut on the standard oleo 63mm (you can inflate the original tyre from 57 to 63mm)
on "the luxe" front oleo (optional) you can use a 76mm tyre.
BUT it wont fit the wheel well , ideal would be 63 front and 74 on the mains
i promisse you one can take of from a potato field...
#65
Hi Big Feet,
many thanks for the help regarding the decals, managed to end up getting them from a company called "Pyramid Models" in the UK, they have a great selection of decals, so now sorted thanks.
Hey Volkan, sorry for hijacking your thread, but the Sprint is looking great, I'm looking forward to seeing it in the air at one of the shows, thanks for an interesting thread.
Regards,
Vince.
Regards,
Vince.
#66
My Feedback: (24)
ORIGINAL: digitech
i was reading this:
i was reading this:
There is room to do it right!
Todd
#67
My Feedback: (10)
ORIGINAL: lov2flyrc
At this moment, I will leave this to the designer to explain. Will follow up with installed pictures early next week.
Todd
ORIGINAL: digitech
i was reading this:
i was reading this:
Todd
mm we got it right?
#72
ORIGINAL: larryfl1
what is the approximate time for a somewhat layman to get this bird together and ready to fly?
The airframe is quick, probably 10 hours, but the installation of radio, turbine and retracts, etc. should be done at your own pace, with care, to avoid later problems and re-fitting.
For a moderate builder, allow another 10 hours or more for that side of the build.
I certainly couldn't get one out of the box and be ready to fly in 10 hours and I designed it!! One days build?????[X(]
In any case, the build is part of the experience of modelling. It is enjoyable in it's own right.[8D]
So enjoy it!!
Alan.
#73
My Feedback: (10)
No i dont work Superfast.
i guess if you do it right at once , you dont need another 2 days to fix it.
it takes me 2 days at my office , wich i do all orders also on those 2 days.
the airframe incl servo,s is assembled in about 3 hours max.
retracts 2 hours max.
the rest is turbine installation.
most work is CG , Deflections , Programming
and making the system bubblefree and testing it.
Elan toulk me also same time...
most time is the delivery it takes to get something.
it takes me a cartidge of Hysol to stenghten some critical points and aluminium pins that fall out here and there.
reglue the Servotray and tank tray.
but they always fly ok...
as you know we test all our gears with your airframes , Before we start selling them.
#74
Hi Guys,
Back to the actual build, the model is almost 99% complete now! Just a few minors bits to do, and Alan picked it up earlier today.
I will be on holiday for a week, but I suspect Alan will be on here soon with pictures of the final model!
#75
My Feedback: (10)
ORIGINAL: volkan
Hi Guys,
Hi Guys,
Parts are send out
incl some Locktite.
