Flash with Crow settings?
My Feedback: (198)
I flew mine with a 120 se and a titan se. Not much difference other then top end speed. Although I could make a slow pass, power up and pull and upline with the titan se.
I don't see any benefit to crow, the Flash slows down to a walking pace for landing with full flaps.
I'm running mine with a Super Eagle, plenty of power and a drop in installation. Ditch the bottom half of the by-pass, the half facing the wing, and you'll notice a nice thrust increase. No need for crow with the Flash, it has a good sink rate with no tendency to float on approach. Reduce the full flap setting 20-25 mm and make sure it is balanced per the manual. Not an incredibly fast jet but it flies on rails!
