Colchester A1 Models BAE Hawk
A local Club member has just purchased this Kit, Just real curious if any of you's have ever had one and if so, what engine did you use
did you fly off a grass field with it, how much does it weigh wet, how much fuel did you carry on it, and of course how did it fly.
There is some good information here http://www.rcgroups.com/forums/showthread.php?t=614461
HI,
There is also a very good thread right here on RCU
http://www.rcuniverse.com/forum/m_27..._1/key_/tm.htm
Greg
Greg
I had one-The most critical point of the whole model - you must have a good elevator servo-9kg to 10kg.Because of the placing of the pivot point the load is massive on the tail plane.
Get all you angles exact.
