 9303 Problems >
9303 Problems
9303 Problems
Old 09-29-2008 | 09:33 PM
Default 9303 Problems
Since I fly jets and use this forum frequently, I have a question about my JR 9303 transmitter. Here is the problem. I select the model I want in the Model Selection section. The system works fine and the jet operates properly. When I turn off the transmitter and cut it back on, the transmitter always goes back to Model 5 every time (not the previous model selected). I have tried to delete Model 5 in the Model Reset section. It appears to delete the Model as normal. When I cut off the transmitter and turn it back on the transmitter goes back to Model 5. I have tried to copy a model to Model 5 but again when I shut off the transmitter and turn it back on, it goes back to Model 5 with no changes. Frustrated!!. Anybody have any suggestions? By the way Model 5 is an F18 I no longer use. The transmitter always goes back to this model when it is cut on.
Thanks for any help.
Jay H
Old 09-29-2008 | 09:50 PM
LGM Graphix's Avatar
My Feedback: (22)
Default RE: 9303 Problems
I would just send it into Horizon rather than take chances with it
Old 09-29-2008 | 09:59 PM
Can you go into a blank model, make some trim changes, etc. and see if it's saving those changes when you cycle the power? Sounds like there's something up with the memory in the radio where it's just not saving changes. Definitely send it in...is it an X9303 2.4 or a module-based 9303?
Old 09-29-2008 | 10:06 PM
I can set up a new model, no problem. When the transmitter is shut down and turned back on it will always go back to Model 5. The trans is a module based unit not a 2.4 system. When a model is selected the selected model works as desired. Only when I shut down and turn back on does the problem occur.
Old 09-29-2008 | 10:14 PM
My Feedback: (22)
can you modify any other model and have it save the changes when you shut it off and turn it back on or does it go back to how it was before you changed anything?
Old 09-29-2008 | 10:17 PM
My Feedback: (10)
I know I saw someone else complain about this on FG awhile back. Can't remember the cause of the problem though.
Old 09-29-2008 | 10:32 PM
Wayne22's Avatar
I have 2 of those radios - one of each, and never encounterd a problem like that.
I'd vote with the others, let Horizon take a look at it......
Old 09-30-2008 | 03:08 AM
Henk Visser's Avatar
Hello send it to horizon we had same problems with spektrum DX7 it's a software buck!
Old 09-30-2008 | 07:40 AM
Thanks for the replies fellas. Trans is going back to Horizon.
Old 09-30-2008 | 11:44 AM
My Feedback: (14)
That could be from battery power. If the power is not enought the radio will not keep the new settings. Or with the internal flash memory. The best thing is send it back to Horizon. Another guy servicing JR Radio is Tony Stillman from Hobby South.
Alex
