changing brands of oil.....
My Feedback: (61)
TX
I have run BP-Exxon 2380 exclusivly, but now i was just handed 5 quarts of aeroshell 500. any problems with my next 5 batches of fuel being an aeroshell mix? after that i will go back to 2380 as it is easy to get locally. jetcats if it matters.
thanks for the input.
Kirk
Kirk
FL
Kirk,
Most turbine manufacturers recommend turbine oil qualified to MIL-PRF-23699.
Aeroshell is so qualified, and recommended by JetCat. See page 11 (Fuel/Fuel Care section) of the JetCat manual.
My Feedback: (33)
Don't get skunned with the oil. Do your homework and you will find that the oil is the same, 99%, and will do just fine. I look for the price. If the numbers are good, no matter the name, the price is right, then that's what I get.
TEEBOX, is not recommendable to use EXXON 2380, he carbonizes, and you have risk to obstruct the injectors and manifold.
You have many other post about this topic.
JOSE [8D]
JOSE [8D]
