Boomerang Nano!!!
#1403
RE: Boomerang Nano!!!
What siclick said, plus I think the rebound on your strut is a bit slow, normally its the compression that is slow and the rebound that is fast to keep contact with the ground to allow steering, otherwise I can see oscillations building up and the nose bouncing around, just a thought.
Mike
Mike
#1404
They sponge mate...same as the baby booma I had changed em out every 50 flights or so landing on Tarmac ...but yes looking for rubber ones right now too
and the rebound is just air and a small rubbish spring to show the travel not the final setup as the setup is not finalised on the model yet, wrote this in my original post "will be setting the spring tension once fitted "
thanx for the suggestions and thoughts
the baby booma had about 800 flights on it and its still going strong,so will be counting the flights on the Nano and in a few years we see...many gear changes where had in the baby and more than a couple of turbines,Had a long chat with Alan about his designs and He rekons the nanao is built lighter but still has inherant strenght so great news as the baby took a serious beating from many a learner pilot and still took off for more...I had to rebuild the retracts bays and a few soft spots on the fuz but nothing major ...can do this if I need too...
before..
and a few days later...
But Had to build that machine first..took me 2 weeks of 16 hours a day to design and manufature on the fly ..no plans where used just common sense a tape measure a caliper and an electric drill a hand saw and a radial armsaw with tunston carbide cutting wheel took me more than 1.5 years to learn the software to run it smoothly as if you where using a pen to write a letter type smoothness I mean so now its pretty much creativity and insperation to make stuff that drives the machine! Have made a few for friends now about 7 machines are spawn from this device..30 helicopters and soo many trinkets ond blingy things I cannot tell...
meet "BLADERUNNER"
and "BIGBOY"
a 5 axis retrofit machine well 4 axis work just making the 5th now..
and a small vid of the 3 axis working...
[youtube]http://youtu.be/BcRMUh4GWWU[/youtube]
before..
meet "BLADERUNNER"
and "BIGBOY"
#1407
Eflight Retractsand Pro strut in the Nose with double wheel....may be a bit long but hey can cut it down as I need to in good time....
http://www.youtube.com/watch?v=vCHAz...ature=youtu.be
#1409
G-Day
Yes it is hooker53
had to cut a little slot to fit them inside the bearers and then superglued a drilled and tapped plate so you can bolt it no worries from the top
Yes it is hooker53
#1410
Sometimes its better to have the retracts screwed down with servo screws as recommended by Alan Cardash, reason being on a heavy landing or normal landing on rough grass as our UK sites tend to be, its better if the retract pulls out rather than rip out the mounts, easy job to make good the hole and re screw them in.
Mike
Mike
#1411
Yes Mike good plan
But!! these electric retracts fit on the other side of the bearer as they are tall units and mounted to the top like normal retract units they stick out by half an inch... So Ive just machine some breakaway spots on the bolts and all good!
cheers
Haydn
cheers
Haydn
#1412
Don't quite understand what you are saying, the electric retracts I have fit the same way as the air retract I have, perhaps a pic may help.
Mike
Mike
#1413
Mike,
That looks like the nose unit with the mounting flanges at the top. I assume the mains are different (and have the flanges at the bottom)?
#1414
All becomes clear, seems a bit awkward though, perhaps there is an alternative nose retract available that does mount conventionally?
From the video (which I have now looked at) it looks like the nose wheel bay has been extended to accomodate the very long nose strut, or is that normal for the Nano? if not this will give massive positive incidence on the wing if the main legs fit in the existing bay I think.
Mike
Mike
#1415
Yes the eflite nose retract is designed to sit on top of the bearers not drop through them, like the type of retract mounting designed (but no one can get) for the elan but bigger,
#1416
Im going to manufacture the main struts and once thats done will trim down the nose leg to suit , Got my P60se Fired up today no problems except a stuck gas solenoid been standing a few months so a quick rap on the table and it started right up reved out and Im happpy to fit it now so can get started on the build and layout
pics to follow
cheers
H
pics to follow
cheers
H
#1417
[youtube]http://www.youtube.com/watch?v=PP85ukVxy-s&feature=share&list=UU44DH8GWvMgg5zGis5FPVTw[/youtube]
Just finnished the construction of the Main Struts ...here they are unpolished , need to source some springs now and get the weighting right once the Nano is complete...
#1420
[youtube]http://www.youtube.com/watch?v=XZHdCp0kRx4[/youtube]
Thanx
here we go starting to fit the retracts and struts with some custom bays ....
IMG]http://i893.photobucket.com/albums/ac140/VanHaydn/20130317_154355.jpg[/IMG]
so just to finish of the pots and decide to cover or paint..
cheers
H
Thanx
cheers
H
#1421
some work on the wells ...may have shot myself in the foot here making them to small...If the gear bends a little it wont fit...so only time will tell...Oh well can always make some more later when im bored!
OR!!! make some plastic vacumed ones from these molds! hmmm yes may do that!
#1422
Trying something different..never done it before so had some fun working it out ....made 2 already that didnt work out but getting better as it goes along....going to have to make a stamp that slides over the top to keep the lines sharp at the base I think ...but its working and great fun!
cheers H
cheers H
#1424
NY
Sluggo,
It would be very tight fit with some weight and balance considerations also. I initially installed an FTE-500 (same case diameter as the Wren 54/Jubilee 80) and had to widen the mounting rails and narrow the turbine mount to get it fitted. I also added about 8 oz of ballast to a hollowed out nose block and a heavy ECU battery to achieve balance. I believe the all-up weight (dry) was about 14 lbs. Later I removed the -500 turbine and installed a Wren 44KGold which lightened up the model to about 12 lbs (dry). The flight characteristics remained about the same but landings were easier with the Wren 44 due to the weight reduction. I plan on replacing the Durbro 50 tank with a 40 oz to further reduce the landing weight. My flight times are about 7 minutes with an ample reserve.
The Wren Jubilee could be made to fit but I'd recommend beefing up the wing-to-fuselage joint and adding some ply doublers to the nose. Also mount your UAT, or equivalent, up front to further reduce the ballast requirement.
Good luck with this and other Nano drivers may chime in also
Art ARRO
Art ARRO
#1425
My Feedback: (55)
Thanks for the info, Arro. I'll probably pass then on getting a Jubilee for the jet. I'd rather not have to do a lot of mods to make it fit.
So now, how about the Jet Central Bee II? Is it a "drop in" fit? I'm just trying to find an alternative to a P60.
Sluggo
Sluggo
