New JetJoe J-Junior 4lbs turbine
#579
RE: New JetJoe J-Junior 4lbs turbine
you dont need the 45 k, 30k is enough.
use the 2 t motor jetcat use.
45K is not even close to the speed these little guys need to start. Reconsider the blower start, you will need a method of getting the blower on to the front of the engine though. One thread had a guy with a 90 deg elbow on his blower to reach into a fuselage. - John.
#582
My Feedback: (9)
ORIGINAL: frema
#583
My Feedback: (9)
ORIGINAL: Boomerang1
Ahhhh....... No. A friend has a blower start Lambert (what the JJJ is copied from) and the idle speed is 100,000 RPM.
Yes, I am sure this is the case too. The JJJ also idles at 100,000 rpm (or there abouts). I will probably make up a 90 degree elbow using conduit or similar.
P.S. You coming to Orange in a couple of weeks?
James.
#584
Yeah....The JJJ idles @ ~99-100k, max's out @ 240k. They require ~65-68k to self sustain depending on ambient conditions....however, what Frema says it quite correct, the small Atomic electric motor will indeed start the JJJ. Once the gas and fuel starts to flow it will help take the load off the starter and much higher rpms will be seen.
A good example is the Wren MW54, they self sustain @ ~ 24-25k-ish, their starters will only "free spin" to ~18k depending on the applied voltage, however when assisted by the gas & fuel will easily run up to and over 30k which is where the starter is usually set to cut out via the ECU parameters, then the engine will happily accelerate up to the normal 40-45k idle from there..
I ran an auto-start Lambert Kolibri a few weeks ago and the starter would free spin the engine to ~38k using just 5.4volts, (it had a 6v electric motor setup), so it still had a bit in reserve. It started the engine fine with no drama at all. Great little engine is the Lambert.
Cheers,
Smithy.
Cheers,
Smithy.
#586
ORIGINAL: jymster
Thanks Smithy,
I think it was you that told me this in an email. Must be on my home PC. I will investigate this a bit further. Looks like the small bendix clutch from Wren might work. Will have to check the ID of the o-ring.
Thanks Smithy,
Cheers,
Smithy.
#589
ORIGINAL: jymster
What motor does the Lambert use?
BS.
#591
ORIGINAL: jymster
Ok, I will have to see if I can get a hold of a bendix clutch from somebody so that i can see how it works and then I can make my own. Maybe Ausjets have a cheap JJ one I could buy to work from?
BS.
#593
ORIGINAL: jymster
Ok, thanks for the offer Brett. I think I will come and pick one up. i have been meaning to call you and arrange a time to come and see you anyway. Will contact you over the weekend.
James.
James.
BS.
#595
I guess it would be nice if Lambert made parts available separately, so that us DIYers can make our own retrofit starters.
Probably about as much chance as getting bits from Wren for the larger engines.
No, I won't be going to Orange but I have been a couple of times, usually a good weekend. Enjoy!
Good luck with your engine - John.
#596
Lambert use the z2 from atomic.
Wow ,then i have a much better junior then you all have
The thrust is also higher 2,3 kg
