A-4 Byron CG
FL
Since I got this kit with formers installed I am not sure if they were glued on the right place - could you please help me a little more. How many inches fron the Leading or trailing edge?
Thanks Again!
Bruno
Thanks Again!
Bruno
ON, CANADA
OK
C of G is 1 3/4" ahead of the front edge fo the wing spar slot in the side of the fuse. Or 9 5/8" back from the leading edge of the wing at the root.
If you using the original wings, the main engine former has to be in the correct location because the spar retainers are attached to it. BTW, the spar retainers should be attached to the back of the former and not the front.
If you need anything else, let me know before I put all back in the box.
Ed
Ed
ON, CANADA
Originally posted by w0mbat
I don't know about you guys but I had to add 1-1/2 lbs to the nose!
Ed
If it helps you any, the CG on the full-size A-4 is 26.4% MAC. Knowing this, you could plot it and safely set it at about 25% MAC.
Good luck!
Larry Wolfe
[email protected]
Good luck!
Larry Wolfe
[email protected]
ON, CANADA
Hi W0mbat
I wouldn't think that puttin two servos in the tail would cause you w add 1 1/2 lbs of weight to the nose unless the Hurricane fan is a fair bit heavier than the Byron fan.
Ed
Ed
