 Fuel... >
Fuel...
Fuel...
Old 03-03-2009 | 03:15 PM
Pete737's Avatar
Default Fuel...
Here comes another noob question [sm=red_smile.gif]? Where do I buy fuel in the RI/Mass area and should I get Kero or Jet-A?
The engine (JC Falcon) has 23 minutes on it. Do I need to find out what it was previously run on and stick with that?
I have searched google but I'm not coming up with anything that helpful?
Also, Would I be best off with one of those extravagant $200 fueling stations or can I come up with something on my own?
Thanks, Peter
Old 03-03-2009 | 03:30 PM
Default RE: Fuel...
cant help with the fuel supplier location but you can used either fuel as long as you add oil, make your own fueling station from a plastic 25lt drum make a bracket for a fuel pump from you local shop add a battery and filter and switch and thats it.
i made my own and its as good as a $200 one
Old 03-03-2009 | 03:32 PM
ravill's Avatar
Default RE: Fuel...
Yeah, you'd be better off with a jersey modeler.
http://www.dreamworksrc.com/catalog/...roducts_id=168
Jet-A: Open up the phone book (or google) airport in RI/Mass. Drive to the closest one and go to the fueling guys. Ask them how you can buy some Jet-A for your bad Arse jet.
Here's my google search for you
http://www.google.com/search?hl=en&q...q=airports+rho
Kero: Buy K-1 from any home depot or other hardware store. I buy Kero from Rotten Robbie there are six near me (Bay area, ca)
Here's one search result for kerosene in your area.
http://www.directory-assistance.net/...nd/255401.html
Now go fly some jets.
Raf
Old 03-03-2009 | 06:37 PM
My Feedback: (17)
Default RE: Fuel...
in the upper states where the cold weather seems to hang on, we can get Kero at most gas stations, and it is selling for about 2.50 a gallon, instead of going to Home depot and paying 8 bucks a gallon for it. 90% of the time I do get it from the corner gas station. but on occasion I do buy it from the airport where we fly the jets and that is Jet-A.....
been useing the pump Kero for 6 years now and NEVER had a problem....
Mark
Old 03-03-2009 | 07:06 PM
highhorse's Avatar
Default RE: Fuel...
Jet-A REEKS compared to K-1. I don't want my shop to stink so much when the INEVITABLE drops leak here and there. Your engine doesn't care what it used to eat one way or the other.
K-1 from the hardware stores is clean and well packaged but in my limited experience is 2x the pump price and unavailable in the summer months anyway. I did a Google search for K-1 or Kerosene +(my city) and found a dealer nearby.
I love my Jersey Modeler fueler, it's very high quality and makes the one I bought from BVM look like something my dog dropped in the yard. Too much trouble to build my own in my case. Whatever U use, consider putting the oil in FIRST and pumping/pouring the fuel in on top of that to facilitate a thorough mixing of the two.
Hope this helped, Don.
Old 03-03-2009 | 08:03 PM
Pete737's Avatar
Default RE: Fuel...
Helps big time!
Does kero exhaust smell the same as JetA? The first thing guys say when they get back from a jet meet is "it smelled like a real jet!"
I think that's coooool!
Thanks so much, Peter
Old 03-03-2009 | 09:03 PM
highhorse's Avatar
Default RE: Fuel...
Nope, smells diffnt when burned too. Cleaner IMO.
FWIW, you do NOT want to be sniffing THESE fumes because the turbine oil is apparently VERY toxic bad doo doo.
Old 03-03-2009 | 11:00 PM
invertmast's Avatar
My Feedback: (23)
Default RE: Fuel...
IMO the kero smell is a bit "cleaner" than the smell of Jet-A but is close enough to the same smell, most dont know any different. I personally have one of the new vent-less style plastic 5gallon kerosene cans from the local hardware store ($25) a sullivan "streamer" fuel pump (No. S754) a see thru fuel filter (from the local auto parts store) a 3S A123 2300 battery, some extra large tygon fuel line, some dubro fuel can fittings and a small micron fuel filter after the pump for my setup. Cost me about $100 and works perfectly everytime
Old 03-04-2009 | 01:41 AM
Stobe777's Avatar
Default RE: Fuel...
Your car will smell less afterwards if You use Kerosene instead of Jet-A1. Anyway, in an air show I´d use Jet-A for the right feeling to the audience. Normal flying and for the sake of less headache-Kerosene.
TP.
