Stingray question >
Stingray question
Stingray question
Old 06-22-2003 | 01:53 PM
mr_matt's Avatar
My Feedback: (10)
Default Stingray question
Hi guys,
Can anyone tell me the length of their nose gear strut on their Stingray?
I am using the Yellow retracts, and I need to know the length of your strut, from the top of the strut to the center of the axle hole. I also need the diameter of your nose wheel.
I know what the plans call for but it does not look correct to me.
Thanks in advance,
Old 06-22-2003 | 04:34 PM
Shaun Evans's Avatar
Matt,
What do you think of those gear? Compared to the others out there of the same size?
Old 06-22-2003 | 05:28 PM
My nose is 5 3/16'' with a 2 '' wheel and the mains are 3 1/4 from the block to the center of the axle with 2 1/4'' wheels. I had to open up the nose gear door area a bit to accomodate the longer nose strut. It sits at about pos 4 degrees.
Chris
Old 06-22-2003 | 06:15 PM
mr_matt's Avatar
My Feedback: (10)
Default HI Chris
Thanks for the feedback.
Do you like the way it handles with so much positiove incidence on the ground?
Thanks again,
Old 06-22-2003 | 06:16 PM
mr_matt's Avatar
My Feedback: (10)
Originally posted by YellowAircraft
Matt,
There are very pretty gear, well engineered and well executed.
Question remains if they are strong enough. Time will tell.
Old 07-03-2003 | 02:27 PM
My Feedback: (17)
Hello Matt,
The way you execute the landing phase, any gear system will last an eternity!!!!!!
Skeet
Old 07-03-2003 | 02:32 PM
Why's that - does he keep landing gear-up to prevent any wear on the gear ?
Gordon
Old 07-03-2003 | 02:39 PM
My Feedback: (44)
Hey Skeet:
I hope to see you at Fresno this year. I tried emailing you but it kept bouncing back!!
Tam's Stingray is almost ready. IF it lasts him more than 3-4 landings, you KNOW the LG is Good
Old 07-03-2003 | 04:33 PM
Skeet,
Are you going to Fresno? If so, let me know. I gotcha covered on entry fee/whatnots.....
Old 07-03-2003 | 09:51 PM
Matt,
I use that same gear on my viper jet. This is 28lb jet with fuel.
It handle fine. My stingray are almost ready for this weeken test flight. I post some photos later. I got your favorite color. Puple metalic, bright green metalic and caution yellow.
I hope the Ram 500 is running. I haven't run it ever since Tony give it back to me.
Brg,
Tam
